Sagging Ceilings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-28-2007, 03:56 PM   #1
jkchapp2
Sagging ceilings
We live in a Bungalow built in 1927. The ceilings in the Living Room and Dining Room both sag. The front half of the ceiling has attic above it with tongue and groove flooring. The other half is Bedrooms. We had water leakage from the roof and will be replacing the plaster ceiling in the Living Room. This I know is a great opportunity to fix the sag in the Living Room, but I am not sure what the best solution would be. Repairs start in less than a month. Any suggestions would greatly be appreciated!
Thank You!
jkchapp2 is offline   Reply With Quote
Old 08-28-2007, 04:20 PM   #2
Back in those days framers didn't care about crown up as "the plaster work will get it fixed. Add time and joist sag under load and you get a bow in your ceiling.
Plan to find lowest point / string the joist to find level / sister 2x6 to all the joists to create a flat new ceiling plane. You can go back with drywall and texure to look like the plaster in the rest of your house.
Plaster removal is very dusty. Know that asbestos was added to plaster to increase working time. Be sure the rest of the house is seal off (don't forget any air ducts).
Big Bob is offline   Reply With Quote
Old 08-28-2007, 06:27 PM   #3
Mod / ArchiBuilder
Cole's Avatar
I would have it tested before I did any demo work of the existing plaster.
Cole is offline   Reply With Quote
Old 08-28-2007, 07:39 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Agreed....
- Build Well -
Old 08-29-2007, 08:48 AM   #5
jkchapp2
inspected
I assume all of you are referring to the asbestos; for the inspection. I live in a small town, check yellow pages for a home inspector or is there another reference to that particular kind of inspector?
Old 08-29-2007, 08:56 AM   #6
jkchapp2
weight limit for ceiling
Another question that was brought to my attention...I plan on installing a 1/2 bath using the original closet, then adding a closet over where the sagging ceiling is now. Will the suggested repair be strong enough so I will not end up with a near future sag in the ceiling? By the way, the size of the Living Room is 16' X 16', Dining Room 16' X 18', original joists go East to West, sag starts on the West wall and droops to center of room where the west wall of the upstairs starts.
Texture coming off of ceilings mrswoodward General DIY Discussions 7 08-16-2007 07:42 AM
Urgent advice needed on sagging roof for home I'm buying jwoair23 Roofing/Siding 6 02-20-2007 11:17 AM
Raising The Ceilings propain Building & Construction 2 06-28-2006 05:33 PM
Sagging roof - framing question G.P. Carpentry 7 12-26-2005 04:32 AM
