Sagging Beam Replacement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-22-2011, 01:20 PM   #1
Sagging beam replacement
Curious to get some thoughts from the pros on this board on what I am doing.
I have a 2nd story room that hangs out about 6' over a garage. I have included a drawing of the layout of the joists and the room above.
My question is: Can I simply replace each joist 1-by-1, whilst supporting the neighboring joists? I'm thinking about using stronger joists like LVL to avoid this problem in the future. Or I-joists, perhaps.
As supports whilst replacing the 2 x 12s, I was thinking about using a 2 rows of 4 bottle jacks and 4 x 4 posts.
Any thoughts or better ideas?
Thanks for any ideas you may have.
Reload
reload is offline   Reply With Quote
Old 12-22-2011, 02:16 PM   #2
Why not just sister new joists next to old ones?
Ninjaframer is offline   Reply With Quote
The Following User Says Thank You to Ninjaframer For This Useful Post:
AGWhitehouse (12-22-2011)
Old 12-22-2011, 03:45 PM   #3
I like the idea. Do you happen to know if that would pass a home inspection?
...not being critical, i just don't know.
Old 12-22-2011, 03:55 PM   #4
Rewards Points: 13,300
If one set passed, adding a second set is sure to also pass.
I would use constrution adhesive and through bolt them with Carrage bolts to pull them up tight. I find it easer to clearance drill the new ones before lifting them in place.
Old 12-22-2011, 04:02 PM   #5
Ok, so surely I would have to add another set of wall studs for this new sister joist to sit on??
Old 12-22-2011, 04:25 PM   #6
Rewards Points: 1,574
A 2" sag seems like a lot to me.
Might want to check if what you are going to sister on to the existing will provide the right support for the live load given the span.
Also, is the supporting wall the joists rest on properly structured? Just asking.
bob22 is offline   Reply With Quote
Old 12-22-2011, 04:55 PM   #7
Well I haven't removed all the sheetrock from the wall, but I did take a small section out and the only thing I noticed was that the joist was not directly sitting over a stud. Don't know how much that matters.
If I sistered a new 2 x 12, the full length, would I have to make a new stud for the sister to sit on?
** Also, the actual sag is probably more like 1-3/4", so not AS bad, but still bad.
Old 12-22-2011, 07:36 PM   #8
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
This is fairly new construction built with 2x6 studs, right? Was this not designed for a load overhead to begin with? Why is it sagging? What is the span of the 2x12s?
With a single top plate, I would sister the studs as well.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 12-22-2011, 08:16 PM   #9
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
I am not surprised the joists area sagging with that structural design.
Did you design this yourself?
Andy.
AndyGump is offline   Reply With Quote
Old 12-22-2011, 09:59 PM   #10
Registered User
Rewards Points: 5,236
I'm glad someone can see the glu-lam, LVL, or paralam missing under the bearing wall carrying 1/2 the roof load plus snow......
At minimum since '76, double joists under bearing running walls (without that mega roof load); http://publicecodes.citation.com/ico...002_par008.htm
Nice drawing though!
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
AndyGump (12-22-2011)
Old 12-22-2011, 11:39 PM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 196
OK, I am just a little thick here, is that a cantilever or are the outer ends of the floor joists supported?
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 12-22-2011, 11:55 PM   #12
Andy.
I greatly appreciate all the constructive comments on this board.
To answer your comment/question, no I did not design this structure. I inherited it.
Old 12-23-2011, 12:04 AM   #13
AndyGump's Avatar
Rewards Points: 664
only the finest.
Andy.
Old 12-23-2011, 12:06 AM   #14
no, sorry, that's just where I ended my drawing.
The joists just continue on out over a 2-car enclosed garage. They are not sagging. Only the 4 joists in yellow are sagging.
Old 12-23-2011, 01:08 AM   #15
Ole Wood Worker
BigJim's Avatar
Rewards Points: 196
Thanks Reload, I understand now. If that were my job I would support all the way to ground or foundation in each wall under the weight bearing wall. I would install a beam that is rated to handle the load of the roof and if it didn't take the swag out of the floor joist I would sister them with LVLs or similar.
Jim
Beam Replacement in Basement dbennett78 Building & Construction 3 04-25-2011 10:02 PM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
Beam Replacement Popeye42 Carpentry 4 12-23-2010 11:29 AM
Sagging Ceiling Joists - Adding Beam In Attic DoItMyselfToo Building & Construction 11 11-30-2010 07:20 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 09:46 PM
