Sagging Beam And Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-14-2008, 07:45 PM   #1
Rewards Points: 12
Sagging beam and joists
I own a 110 yr old row house that measures roughly 36'x20'.
7' from the Western wall is a beam (2 2x6's) that is load bearing to the 1st and I presume the 2nd and 3rd floors. Currently it is is supported by 2 vertical 6x6's and two jack posts. Otherwise, the joists run to the stone foundation that is in good shape.
The problem: The floor dips significantly to a low spot that is ~equidistant from the front and back of the house and ~9 feet from the western wall. The dip is very noticeable to me - 1 1/4" over 8'. The dip is only noticeable in the kitchen, as the 2nd and 3rd floors are ~level. The dip occurs directly over one of the jack posts.
The question: How do I go about leveling the kitchen floor?
I'm considering placing a 10-12' steel beam under the main beam and supporting it with the existing jack posts.
I am also considering adding a second beam on similar posts, ~8 feet from the eastern wall. What supports would I use? Would it need to run that beam the entire length of the house, or could I get away with just running it under the 10-12 feet that really needs support?
I'm decent with how to build new, but I completely lack the experience to know how to re-engineer safely and efficiently.
Any information greatly appreciated.
Soparklion is offline   Reply With Quote
Old 04-15-2008, 01:11 AM   #2
BuilderRemodeler
Building Inspectors are helpful usually.
Sounds like you are on top of things.
The Adjustable metal Columns are a good rout to go under your beams so you can work the areas up gradually.
BuilderRemodeler
40 pages of useful Home Remodeling Charts, Home Addition Guidelines, Home Painting Tips, How to Determine a Deck Size and Build Your Deck Online! www.BrandsConstruction.com
www.HomePlansForFree.com One Story Ranch Detailed Free Home Plans
darylbrands is offline   Reply With Quote
Building short section of wall to support new beam. Clutchcargo Building & Construction 5 04-13-2008 10:30 PM
hanging ceiling above the joists?.... mben Building & Construction 18 04-01-2008 05:47 PM
Basement Beam and Columns..... shamrock33 Building & Construction 1 03-19-2008 06:03 PM
Securing ceiling joists to a beam t_mccann Building & Construction 9 11-28-2007 03:35 PM
Floor Support Beam SlipperyPete Building & Construction 3 12-04-2006 06:55 AM
