RV Driveway - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-19-2011, 10:47 PM   #1
RV Driveway
I am having a 1400 sq ft driveway laid for my motorhome to be parked on should I have fibermesh or reinforce steel or both put in and how thick should the concrete be
debwhe25 is offline   Reply With Quote
Old 05-19-2011, 11:20 PM   #2
Rewards Points: 1,016
Rather than concrete I installed a DG driveway to my workshop and RV parking. Works great and way cheaper than concrete.
____________
Vince
Old 05-20-2011, 01:18 PM   #3
Rewards Points: 4,656
depends - is your m/h on a toyota mine-p/u chassis OR the big kind ? save your $ on the fiber BUT use ( at least ) #5 rebar under the wheels,,, the most important way to prevent random cracking is diamond-sawing the proper joint pattern,,, i'd have 6" conc w/8" under the wheels - parked ( static ) loads ' weigh ' more in that they'll damage base & cause cracks MORE than dynamic ( rolling ) loads
Concrete Driveway - Asphalt Over Top? mark2741 Building & Construction 1 03-22-2011 03:42 PM
Bad driveway patch and seal work fastfan Landscaping & Lawn Care 1 09-09-2009 08:14 PM
Bury my old driveway problems? kingcire Landscaping & Lawn Care 3 08-10-2009 04:47 PM
Need to have driveway paved and graded Mikey Palmice Landscaping & Lawn Care 3 05-20-2009 07:07 PM
Question about convrete driveway Laser4G63 General DIY Discussions 8 02-12-2009 05:19 PM
