Rusty Screws In Exterior Walls - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-11-2009, 08:52 PM   #1
Rusty screws in exterior walls
I am hoping to get some insight to a problem that I ran into today. Here is a little background. I have a single family ranch style house that is aproximately 6 years old (located in Illinois). About 2 - 3 years ago, I hung a couple of lamps in my son's room on an exterior wall with a southern exposure and a picture in the master bedroom with a western exposure. I am in the process of preping these rooms to get repainted (changing decor) and when I removed these screws, three of them were rather rusty. Two of the eight in the southern exposure wall were rusty and the one in the western exposure wall. This seems to tell me that this is some sort of moisture in these walls, but I am unsure as to how much. All three of these screws were set into anchors in the drywall and were not directly in the studs. I am assuming that the best thing for me to do is to open the wall near the floor in these spots to inspect the insulation and the backside of the drywall and house sheating. Anyone have any other ideas for me or anything else that I should look for? There are no visible signs of mold on any surface in our house, but I have had another issue with moisture in the house. I had to replace the front door in the house because the framing had rotted and started to fall apart. Any tips or other suggestions will be greatly appreciated. Thanks
DIYIllini is offline   Reply With Quote
Old 02-11-2009, 10:00 PM   #2
Registered User
Termite's Avatar
Tearing into the wall is one option, but you never know what if anything you'll find.
Something that might be worth looking into would be to have an inspection company come out and use an infared camera to "look into" your walls. The IR cameras easily identify air leaks and water infiltration, as well as poorly insulated areas. The nice thing is that they work just like a video camera and don't require you to make holes in the wall.
Your home may simply lack a moisture barrier of any kind under the siding, which would make it a lot easier for humidity from the outdoor ambient air to enter the exterior wall cavities. It could be a leak or two. It could be nothing. Perhaps those screws weren't treated with zinc or anything at all to keep them from rusting really easily.
Old 02-12-2009, 06:44 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Since not all of the screws were rusted, I would lean toward the possibility that the screws weren't all finished or plated in the same manner. If you have a concern about moisture or air infiltration, then I would definately do as Termite says and have it scanned before I would demo anything.
Old 02-12-2009, 07:15 AM   #4
BUILDER / REMODELING CONT
buletbob's Avatar
the screws also could of penetrated the vapor barrier of the insulation? BOB
Old 02-15-2009, 01:26 PM   #5
Thanks for the things to think about. I think that you guys hit it on the head. I guess that I saw the rusted nails and jumped to the worst. Thanks for bringing me back to earth before creating more work than needed...
I can't get tapcon screws to tap into the concrete slab!? Monty Building & Construction 24 08-07-2010 07:08 AM
New Drywall Installation, 1 joint screws are popping zjowens Drywall & Plaster 29 01-02-2009 12:26 AM
Screws vs Nails in Interior framing project alexz Building & Construction 2 07-05-2006 05:58 AM
DECK decking nails vs screws ... christian15213 Building & Construction 8 05-02-2005 07:51 PM
