Old 01-20-2013, 09:56 AM   #1
rusting support pole
I have metal support pole in my garage that is rusting out on the bottom due to melting snow from the cars during winter. I don't know how thick metal is but it looks bad. Are those poles filled with something or they hollow?
jansade is offline   Reply With Quote
Old 01-20-2013, 10:31 AM   #2
Some are, some are not, no way to tell from here.
Got a picture?
Old 01-20-2013, 10:41 PM   #3
Your own garage, so probably one family house, so those columns are usually hollow. You can tap on it with a hammer to hear. The column is also 1/4" thick. Scrape the rust away and see how much of the metal you can remove. Those columns can rust away. I would recommend primer and paint, and trying to keep them dry.
carpdad is offline   Reply With Quote
Old 01-21-2013, 05:23 AM   #4
carp's right,,, i always thought supporting columns had to be fill'd w/conc to meet fire code - heard it from an inspector/engineer/newbie laborer know-it-all on a job maybe dan will chime in on this
taxpayers voting for obama are as idiotic as chickens who voted for Col. Sanders !
if you hear it from a guy in the apron store, be VERY suspicious the mtl/method will work,,, when it time to build something together, they won't answer phones NOR help
itsreallyconc is offline   Reply With Quote
Old 01-21-2013, 08:51 AM   #5
Super Moderator
Most are hollow in this area---
Old 01-21-2013, 09:59 AM   #6
Windows & Dogs
Taylor Rae's Avatar
I've had to cut a couple that were older and they were concrete filled. However, I do know that they can be hollow. If your unsure with the tap test then just drill a small hole in it to find out if there's concrete inside. In any case It does have to be addressed before it rusts out completely.
Taylor Rae is offline   Reply With Quote
Old 01-21-2013, 11:28 AM   #7
Roofmaster
Jack and hold with a 4 x 4, replace with a Galvanized pipe with 1/4 inch Galvanized Pads. Why Worry?
" A lot of men build things, and a lot of things fall down "
Old 01-21-2013, 01:00 PM   #8
GBrackins's Avatar
depends on whether lally columns or standard pipe columns where used. As stated tap and listen .....
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Single Pole vs. Double Pole Thermostat dforeid Electrical 14 08-26-2012 09:12 AM
Support pole for front door awning is loose techman41973 Building & Construction 2 02-08-2012 12:25 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 09:38 PM
double pole breaker + outlets / x10 BlueBSH Electrical 0 09-09-2010 01:44 PM
Install glass tile on wood stud pole (for support beam) chatelain Remodeling 1 06-21-2009 11:45 PM
