-   -   rusting support pole (http://www.diychatroom.com/f19/rusting-support-pole-169596/)
jansade 01-20-2013 09:56 AM
I have metal support pole in my garage that is rusting out on the bottom due to melting snow from the cars during winter. I don't know how thick metal is but it looks bad. Are those poles filled with something or they hollow?
joecaption 01-20-2013 10:31 AM
Some are, some are not, no way to tell from here.
Got a picture?
carpdad 01-20-2013 10:41 PM
Your own garage, so probably one family house, so those columns are usually hollow. You can tap on it with a hammer to hear. The column is also 1/4" thick. Scrape the rust away and see how much of the metal you can remove. Those columns can rust away. I would recommend primer and paint, and trying to keep them dry.
stadry 01-21-2013 05:23 AM
carp's right,,, i always thought supporting columns had to be fill'd w/conc to meet fire code - heard it from an inspector/engineer/newbie laborer know-it-all on a job :laughing: maybe dan will chime in on this
oh'mike 01-21-2013 08:51 AM
Most are hollow in this area---
Taylor Rae 01-21-2013 09:59 AM
I've had to cut a couple that were older and they were concrete filled. However, I do know that they can be hollow. If your unsure with the tap test then just drill a small hole in it to find out if there's concrete inside. In any case It does have to be addressed before it rusts out completely.
jagans 01-21-2013 11:28 AM
Jack and hold with a 4 x 4, replace with a Galvanized pipe with 1/4 inch Galvanized Pads. Why Worry?
GBrackins 01-21-2013 01:00 PM
depends on whether lally columns or standard pipe columns where used. As stated tap and listen .....
