Rustic Corrugated Metal Panels As The Ceiling ? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-14-2010, 11:03 PM   #1
Buffalogirl's Avatar
Rustic corrugated metal panels as the ceiling ?
I had the spray foam application done on my cabin, ceiling, walls and all. The manufacturer said I didn't need vapor barriers or such. I hope he wasn't lying.
Now I'm deciding whether to put the rustic corrugated metal panels as the ceiling. It would be the most economical option that I could do myself, plus it would offset the cost of the spray foam.
Anyone see a problem in that? The layers would be; roofing metal that are attached to the wood strips, that are attached to the 2X6 rafters, the spray foam, then the corrugated metal panels.
Any suggestions for alternate cathedral ceiling applications that are somewhat economical?
BuffaloGirl in Arkansas
Buffalogirl is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling Fan with Light kit - Light not working aadams Electrical 12 11-03-2010 07:32 PM
Using metal studs with a suspending ceiling MinerReb Remodeling 7 04-02-2010 06:57 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 06:16 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
