Rusted Basement Column - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-29-2009, 11:53 PM   #1
Hello
I'm looking for some opinions on what to do with a rusted basement column. It is the middle column in the house and all of the other columns are ok. There was a faucet where a washing machine used to be located. Apparently it leaked onto the beam for a long time. The flanges on the beam are very rusty but seem to be structurally ok. The web, which took most of the water damage, is partially rusted out. I talked to a building inspector and some other people I know, and most of them thought it could be repaired. But I was looking for some other opinions. Do you think it can be repaired or do you have any recommendations? Or should I just call a professional and have it replaced.
Ben
bbrown567 is offline   Reply With Quote
Old 03-30-2009, 06:52 AM   #2
Not used to seeing a vertical 'I' beam in a house. I assume it holds up a main beam of the house??? It takes a lot to rust out the 1/4" steel in an I beam, and the pic is not that specific. If it supports the middle of the house beam. consider replacing it with a solid(concrete filled) lolly column. But get a first hand opinion, we are only looking at a picture.
Old 03-30-2009, 10:29 PM   #3
Yes it holds up the main beam. I will get some more opinions. Thanks for the comment.
Old 03-30-2009, 10:48 PM   #4
Go to you favorite home improvement store such as Lowe's or Home Depot and have them order you an adjustable column. They don't stock them. Don't get those cheap temporary columns that bolt together as they are only for temporary installations. I think the 10' columns I used were rated for 14,000 lbs.
The columns typically have 3"-4" of adjustability.
KHouse75 is offline   Reply With Quote
Old 03-30-2009, 11:03 PM   #5
Rewards Points: 150
You could buy two, rig one up right next to the old ibeam, take the weight off, remove the ibeam, and replace it with the 2nd column. That's what I did with mine.
then return the other column
KHOUSE your HD didn't stock them? Mine had about 100 of 'em.
johnnyboy is offline   Reply With Quote
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
basement floor drain problem radioiowa88 Plumbing 5 10-22-2008 11:52 PM
lally column loosed from basement floor sonofthetonsured Building & Construction 8 06-28-2007 02:24 PM
Temporary support for replacement of basement beam Mikedks Remodeling 8 09-14-2006 07:36 PM
