Rust Stains From Railing On Concrete Walk - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-04-2009, 10:40 PM   #1
Rust Stains from Railing on Concrete Walk
We have a metal railing around our front porch which is embedded in our concrete walkway. There are a couple of areas on the railing which are starting to rust a bit so I am getting ready to sand, scrape and then paint the entire railing (using Rustoleum paint). However, there seems to be a fair amount of rust stains emanating from where the railing is embedded in the concrete walk. I will of course redo this area, but I am wondering if there is anything else I can do to avoid this problem again in the future.
Thanks!
stubits is offline   Reply With Quote
Old 06-04-2009, 11:55 PM   #2
Licensed P.E./Home Insp
Aggie67's Avatar
Rewards Points: 812
Before replacing the concrete, try removing the stain:
1. first try a gunite rust eraser, found at pool supply places (the tan ones, not the black ones)
2. if that doesn't work, buy a bottle of 1000 mg vitamin c tablets, CRUSH them up, put them in an old nylon stocking tied up in a ball/pouch nice and tight (20 tablets per nylon pouch), soak it in a cup of water for 5 minutes, and place it on the stain. Leave it there for 2 hours, and every 15 minutes check it and drizzle a 1 oz shot of water on it. When the stain is gone, hose off the concrete. The concrete may clean up cleaner than the surrounding concrete, so check it often.
If you do replace it, seal it. It may still rust, but it will be slightly easier to remove with the above methods. Strict prevention involves strict maintenance on the coating.
Aggie67 is offline   Reply With Quote
Old 06-05-2009, 06:20 AM   #3
sealing the conc would help solvent-bas'd sealers're best but be prepar'd to do this semi-annually w/the stuff we use ( elitecrete's ' css ' ) or annually w/anybody else's stuff
yesitsconcrete is offline   Reply With Quote
How To Keep Your Concrete Mixer Driver Happy Mort How To Guides 38 02-12-2014 07:25 PM
Railing on walk out roof MisterK Roofing/Siding 1 08-14-2008 11:42 AM
PVC Railing on Concrete kabbak Building & Construction 2 01-27-2008 06:19 AM
When is it safe to walk on fresh concrete? chaddihimself Building & Construction 4 08-13-2007 01:34 PM
rust stains on roof mgaa HVAC 2 09-28-2006 12:32 AM
