Running Piping Through A Brick Facade - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-28-2008, 12:47 AM   #1
Rewards Points: 1,088
Running Piping Through a Brick Facade
If you had to route PVC piping outside of a house and your exterior was all brick (facade) with wood sheathing as the backing, would you go through the trouble of finding a masonry hole saw and cutting the nice hole, or would you just use masonry drill bits to drill a line of holes and then just chisel the piece out? I may have to run a 1.5" PVC pipe outside.
handy man88 is offline   Reply With Quote
Old 05-28-2008, 09:53 AM   #2
Registered User
Termite's Avatar
Use the right tool for the job. Look at it this way...It is an excuse to buy a new tool.
I'd spring for the holesaw.
Old 05-28-2008, 10:21 PM   #3
I've had luck drilling a bunch of holes and cleaning up the hole with a hammer. Then caulking around the pipe to cover up any ragged edges. Sure you could buy a holesaw but I'd rather buy a tool I'll use more than once. My 2 cents.
Stan.
smcmurrey is offline   Reply With Quote
Old 05-28-2008, 10:30 PM   #4
Underground Techie
sevver's Avatar
I would get a drycore bit. Drilling a bunch of holes right next to each other is a nightmare. It keeps on wanting to go back into the other hole.You could probably even rent a drycore bit and chuck it in your own hammerdrill if you have one and have it done in less than a minute.
sevver is offline   Reply With Quote
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 05:26 PM
20 year old Brick Wall Repair Bobrobert General DIY Discussions 15 11-22-2011 04:07 PM
Bad Brick Mortar ??? kourso Building & Construction 21 11-08-2010 01:11 AM
Brick: to paint or not to paint, that is the ? Turnip Painting 3 04-15-2007 11:06 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
