RTD Plywood - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-21-2009, 04:18 PM   #16
Registered User
Rewards Points: 526
I agree with Daniel on the rtd, as anytime I found it mentioned was to plywood manufacturing. Though all my research has shown APA uses the same glue in Exterior and Exposure 1 grades, only the bond durability has changed from the application. Also, 1/2" CDX is not warranted by the manufacturer for underlayment for tile, only as roof or wall sheathing, because of the knot holes and other voids. But now I'm nit-picking. Be safe, G
Old 11-24-2011, 03:40 PM   #17
I bought some of thaRTD at HD and "Ready to Delaminate" seems most accurate. Several 4 X 4 pieces I had stored in a covered protected outdoor area warped badly and started to delaminate after a rain. They did not get wet, only exposed to high humidity. Some scraps I left out in the actual rain completly came apart !! I am not impressed with this stuff. Guess thats why its cheap at 13+ $ a sheet.
mdmike52 is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Tiling - Gap in plywood (sub)floor mcg Remodeling 5 01-15-2009 04:21 PM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 12:11 PM
Removing kitchen tile with plywood under it ediconu Flooring 4 08-26-2007 08:48 PM
