RTD Plywood - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-20-2009, 09:36 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
RTD plywood
I went to HD looking for CDX plywood but they didn't have it. In the spot where they usually stack CDX, they had RTD plywood. It was Exposure 1, SYP (Southern Yellow Pine) but I have no idea what RTD stands for. Anyone know?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 06-21-2009, 12:37 AM   #2
Registered User
Rewards Points: 5,516
http://www.conaxbuffalo.com/case_rtd_plywood.aspx
Be safe, G
Old 06-21-2009, 06:12 AM   #3
the Musigician
DangerMouse's Avatar
i must be a Real True Dumb@$$, cause i read that page and still don't know what it stands for.
heck, i don't know what CDX stands for either! lol
DM
Old 06-21-2009, 07:36 AM   #4
I have gas!
Is RTD the next generation of CDX? Is delaminating a problem with CDX?
Does Exposure 1 mean it's for damp wet conditions?
Old 06-21-2009, 08:59 AM   #5
the Musigician
found this.....
Exposure durability classifications are assigned on the basis of raw material composition and
adhesive bond durability. Panels are typically produced to one of two classifications: Exterior or
Exposure 1.
Exterior panels are designed for applications subject to permanent exposure to weather or moisture.
They are fully waterproof. Exposure 1 panels are suitable for uses that are not permanently exposed
to the weather, but where panels must resist effects of moisture due to construction delays, high
humidity, or other conditions of similar severity. Exposure 1 panels have a fully waterproof bond and
are made with the same exterior adhesives used in Exterior-rated panels. However, building products
distributors and builders are cautioned to store panels on skids off the ground and to tarp the unit
when there is potential of heavy rain or snow.
In the case of plywood, Exterior-rated panels are manufactured with C-C and better grade veneers,
while Exposure 1 panels are classed as "Interior with exterior glue" panels because they can be
constructed with veneer of D grade and better.
anything that touches the ground or sits on outside concrete has to be made for "ground contact".
different PT chemicals, and REALLY heavy as it's pretty much soaking wet.....
DM
Old 06-21-2009, 09:13 AM   #6
I have gas!
A brief search reveled that CDX has the same rating (Exposure 1), so I guess RTD is the next generation of plywood.
Old 06-21-2009, 10:12 AM   #7
RTD - Reduce The Defects
Old 06-21-2009, 10:22 AM   #8
I have gas!
Or another one that I found while researching.
RTD = Ready To Delaminate.
Old 06-21-2009, 10:51 AM   #9
the Musigician
oh man, you guys are Really Trying Desperately here.....
DM
Old 06-21-2009, 10:55 AM   #10
Custom Cabinet Maker
Mouse! C D X C face, D face X exterior glue :}:}
RTD? Ready to take a dump???????????
Seriously tho, from what I read and searched for it seems that RTD is a process used to make the plywood. It supposedly improves the glue bond between layers thru better control of the heat and steam needed, therefore less delamination in use. At least that is what I brought away from reading.
skymaster is offline   Reply With Quote
Old 06-21-2009, 11:04 AM   #11
the Musigician
why are you telling me? Clutch was asking...
and it's down the hall, last door on the left.....
DM
Old 06-21-2009, 11:13 AM   #12
Civil Engineer
Rewards Points: 4,780
An RTD is a resistance temperature detector. It is essentially a thermocouple, designed to provide real time, very accurate temperature readings. RTD plywood appears to be exposure grade 1 plywood manufactured using RTD technology to control the temperature of the glue during application and curing. Presumably this makes the plywood superior to CDX plywood, which by the way stands for C face on one side, D face on the other side, exposure grade 1.
CDX is NOT exterior grade plywood. Exterior grade plywood uses superior glues to CDX. Since CDX is exposure grade 1, it is suitable for use as a substrate in damp environments, such as sheathing for roofing, or underlayment for tile. RTD plywood appears to refer to the manufacturing process; the only way to know the exposure class on RTD plywood would be to check the rating on the sheet, it should be stamped on the sheet.
Old 06-21-2009, 11:24 AM   #13
DM
ROFLOL OK Mouse this is why :}:}
Daniel; thankx all my years I have been told cdX was exterior glue. Never mind ROFLMAO
Old 06-21-2009, 12:36 PM   #14
the Musigician
to me it's just always been plain, pressure treated, or ground contact i've ever needed.
i guess i never paid attention to abbr.
DM
Old 06-21-2009, 01:51 PM   #15
Yes I am dyslexic OAFMLFOR I just can reads backasswards
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
Tiling - Gap in plywood (sub)floor mcg Remodeling 5 01-15-2009 04:21 PM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 12:11 PM
Removing kitchen tile with plywood under it ediconu Flooring 4 08-26-2007 08:48 PM
