ROXUL Hung On Existing Ceiling --How? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-03-2013, 10:06 PM   #1
JPM
Bill Traver
Rewards Points: 93
ROXUL hung on existing ceiling --How?
Read about soundproofing and I was thinking of adding a layer of the ROXUL safe and sound to and existing plaster ceiling that has a drop ceiling underneath it. The drop is about 1 1/2 feet. Both are old, from prior owner, but functional ... need everyone's thoughts and ideas on how best to get the ROXUL up there.
THANKS!!
JPM is offline   Reply With Quote
Old 08-03-2013, 10:35 PM   #2
Just move the tiles out of the way and proceed.
What is above the actual ceiling (not the suspended ceiling)? Can you access the attic? If so, it would probably be easier to add insulation in the attic rather than attempting to squeeze the insulation around whatever is living above the suspended ceiling.
Why roxul? It's a nice product, but isn't it rather expensive?
jponto07 is offline   Reply With Quote
Guidance needed with existing wiring - Ceiling fan install rickkrause2001 Electrical 4 03-23-2012 04:33 PM
Plaster ceiling with peeling paint annaem Painting 14 01-19-2012 01:10 PM
How to wire a 2-prong lamp to a ceiling mount with an existing ground cyantific Electrical 1 08-19-2008 06:22 PM
Blending ceiling patch with existing sheet-rock (slight texture) gmhut Painting 3 07-29-2008 12:16 PM
Drywall over existing ceiling? billybarty Carpentry 1 03-08-2008 12:05 AM
