Old 02-27-2011, 01:23 AM   #1
Roxul Heads Up
My local Lowes has started carrying Roxul ( special order ) .
Previously it was available nowhere close at all.
I have some on order and would suggest to check with Lowes
if your having some difficulty finding it.
High Gear is offline   Reply With Quote
Old 02-27-2011, 09:48 PM   #2
iminaquagmire's Avatar
Roxul Heads Up
Home Depot can special order it as well. It comes through PrimeSource, the company they get their nails and screws from. It took some calling around to different distributors but they found it for me. They have a minimum order of three bags. it was actually cheaper than buying the fiberglass off the shelf IIRC.
iminaquagmire is offline   Reply With Quote
Old 02-27-2011, 10:41 PM   #3
Roxul Heads Up
I haven't tried HD ( even though I understand Canada HD stocks it )
because Roxuls site only lists independent stores ( in my case ) about an
hour away from here.
HD I see you have to go in and see if they can special order , Lowe's pulls
right up on the web site and it can be ordered from home.
I probably should have tried Menards ( if they'll spc order ) as they are
light years ahead on customer service , Lowes a distant second and HD
has really slipped over the years here.
Do screw heads really need to be mudded with three coats? KUIPORNG Remodeling 33 09-17-2011 02:54 AM
Lawn sprinkler system - changing heads - ? SixStrRzr Landscaping & Lawn Care 1 08-16-2010 09:01 PM
Adding a few sprinkler heads to existing argh Landscaping & Lawn Care 9 08-03-2010 01:07 AM
multiple shower heads mbrewmeister Plumbing 1 05-29-2009 07:04 AM
Testing a Central Vacuum with no hoses or heads MrLinux General Discussion 1 01-23-2008 04:44 PM
