Rounding Attic Ceiling Plaster - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-28-2009, 07:42 AM   #1
Question
rounding attic ceiling plaster
I have a quote for plaster for an attic room. He said that he would round the transition from the sloped ceiling to the flat ceiling because it would be really hard to keep a straight line with a sharp angle.
Any comments?
luci468 is offline   Reply With Quote
Old 05-28-2009, 07:52 AM   #2
Rewards Points: 352
Rounding will allow room for error in the framing. If you want to check just run a string along the angle. If it is off by more than 3/8 or so between studs stick with the rounded corner. I think it adds interest to the room but if you want that straight line look you could paint with two different shades using a tape line to divide the top and bottom.
Rege
RegeSullivan is offline   Reply With Quote
Old 05-28-2009, 08:36 AM   #3
Old School
Willie T's Avatar
Same answer as in the other forum.
Willie T
Tags
attic , ceiling , plaster
Snow in attic through mushroom vents,leaking into great room ceiling thom risley Roofing/Siding 17 02-03-2014 03:47 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
rounding transition in attic ceiling plaster luci468 General DIY Discussions 2 05-28-2009 08:28 AM
question about running romex in attic ceiling jayp Electrical 5 03-20-2009 01:06 PM
Garage ceiling and attic storage DIY KEN Building & Construction 7 01-06-2009 04:57 PM
