Rough In / Stud Wall Location Help? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-16-2008, 08:02 AM   #1
Beer Advocate
Taipans's Avatar
Rewards Points: 150
Rough in / stud wall location help?
My basement has a rough in for a 3/4 bathroom. I am getting ready to put up the framing for around this area. My question is, how far do I set the walls away from the shower drain pipe? I'm guessing there has to be some standard for this, or atleast a common size needed for most shower inserts?
Thank you
Taipans is offline   Reply With Quote
Old 06-16-2008, 08:09 AM   #2
Registered User
Termite's Avatar
If you're using a shower insert, you need to check the manufacturer's specs. Nothing is standard, and the wall and drain locations must exactly match the insert's dimensions.
Old 06-16-2008, 08:24 AM   #3
shower inserts come in different sizes and have the drains in different locations like center drain top drain or offset so it all depends on which inset you chose for the space you have,or weather you are building your own shower from scratch but as far as I know their is no standard for where the walls can be set until you know what your putting in
clasact is offline   Reply With Quote
Old 06-16-2008, 03:26 PM   #4
Rewards Points: 156
buy your shower
Buy your shower or tub and follow the rough in guide.
jayp is offline   Reply With Quote
Old 06-17-2008, 09:18 AM   #5
Beer Advocate
Taipans's Avatar
Rewards Points: 150
Ok, thanks guys!
Old 06-17-2008, 10:29 AM   #6
Mechanical Engineer
comp1911's Avatar
Rewards Points: 150
Some manufactures have the rough in guides online. No need to buy the insert right away then.
comp1911 is offline   Reply With Quote
Old 06-17-2008, 11:50 AM   #7
RippySkippy's Avatar
Or plan on make your own tile shower and forget dealing with a mfg'd shower pan. Lot's of flexibility.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 06-17-2008, 03:48 PM   #8
Registered User
Termite's Avatar
But a lot more work, especially for a DIYer! I'm neck deep in my own custom shower nightmare right now. I'd be done remodeling the bath if I had used an insert...Instead my evenings and weekends have been spent building pre-pans, bases, seats, curbs, membranes, and lots of endless tile work. It looks a lot nicer, but causes more work for sure!
Old 06-17-2008, 04:01 PM   #9
kctermite I got two downstairs and one up and only got one done or almost done I should say.It is alot of work but to tell the truth I just don't like the prefab look alikes and wanted something with my own touch on it but I do think for the one up stairs I might just get one of those steam shower set ups and build around it.I just cant see lugging all that tile and concrete up the stairs I'm getting old
Old 06-18-2008, 08:18 AM   #10
@thekctermite Won't argue that it's more work, and I guess that's one of the reasons I like it. When you get done, you'll have a beautiful shower, almost a work or art when it's done. Have you used the kerdi product? It's beautiful to use, and really takes the pain out of the curb/seat/niche/pan building. Highly recommended in my opinion. Expensive yes...but it also delivers a comforting peace of mind.
LMASD
Old 06-18-2008, 08:39 AM   #11
Registered User
Termite's Avatar
Didn't use Kerdi. I did a vinyl-rubber membrane under a mud pan on a preslope mud pan, and integrated drain. Wasn't too tough, but a little scary. I waterproofed the wonderboard on the walls with ProGuardHDG, which is a similar product to RedGard.
Agreed, tiled showers are nice looking. Mine's going to be awesome when it is done......Someday.
Old 06-18-2008, 09:41 AM   #12
Originally Posted by thekctermite View Post
....Mine's going to be awesome when it is done......Someday.
Aw...c'mon...like you're the ONLY one that's ever said "that" before!
Give the kerdi a shot some time...it's a great product.
LMASD
Replacing stud wall behind brick bayoudonnie Building & Construction 1 05-19-2008 09:34 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
How to butt wood stud wall to steel stud wall? Yorkergizer Building & Construction 3 12-01-2007 12:28 AM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
