Rough Opening For Door Only 80 1/2" - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-31-2012, 01:19 PM   #1
Rough opening for door only 80 1/2"
I have a door underneath some duct work that I had to box in, but the height of the rough opening is only 80 1/2" high. I was planning on installing a prehung door (this design to match the rest of my home), but on the website it states that the rough opening should be 82" tall. Now I was thinking, maybe I can just trim off the frame on the bottom. Or can I not use pre-hung doors in this case? Or would I have to custom-order a 78" door instead?
TomU is offline   Reply With Quote
Old 12-31-2012, 01:58 PM   #2
Rewards Points: 2,210
You should be able to trim off the bottom, but the door will look a little different especially if it is near other doors.
Also depends how much is at the bottom before any designs start.
mae-ling is offline   Reply With Quote
Old 12-31-2012, 02:06 PM   #3
funfool's Avatar
Rewards Points: 534
Yes
No
Maybe
You can use pre hung doors and cut them down, is done all the time. What matters is the style and quality of doors.
You are talking cutting 1 1/2" off bottom of door, some hollow core interior doors only have a 1 1/2" solid wood piece on the bottom. I recently seen one with only 3/4" on bottom.
When you cut this much out , now will need to rebuild and add some support into the bottom of the hollow core door. You basically destroyed the integrity of your new door, but can be repaired.
If you have a six panel door, order it in solid wood, you now have a choice to stain or paint to match your other doors ... could cut 3" off rhe bottom and not hurt it.
funfool is offline   Reply With Quote
The Following 2 Users Say Thank You to funfool For This Useful Post:
mae-ling (12-31-2012), woodworkbykirk (12-31-2012)
Old 12-31-2012, 03:39 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,062
your right.. almost all prehung and hollow core doors from bigbox stores now do only have a 3/4" filler strip on the bottom and at hte top.. not only are they more prone to being broken but theres less meat to pin to if you have to cut down the door... if you have baseboard door stops installed the stopper can easily punch through the door
for this reason i only install solid doors on the homes i trim unless the door is for a linen closet or a side room in a basement.. also with solid doors they dont warp as easily and the main reason, they help cut down on sound transfer
woodworkbykirk is online now   Reply With Quote
Old 12-31-2012, 09:46 PM   #5
Rewards Points: 534
If you cut too much from bottom, it changes door knob height..a small point.
Depends a lot on your finish floor. It changes available height. Recommended rough opening is for having plenty of room for adjusting to uneven floor, uneven framing, having to shim, etc. You don't actually need 82". Even 1/8 space from floor to door is fine as long as the door opens. You don't even need top jamb. You definitely do not need a header, even a 2x4 on its side. If your finish ceiling/duct cover does not call for a trim detail, I would think about getting rid of the top jamb. If you want a trim around the door, cut the door from both bottom and top-whatever you need, reposition the top jamb and use it to nail the strip of trim.
I would try to keep the finish door opening to 80".
carpdad is offline   Reply With Quote
The Following User Says Thank You to carpdad For This Useful Post:
Old 12-31-2012, 10:53 PM   #6
Good point. YOu do not need a top header or even 2x4. Just use the top door jamb there.
Old 12-31-2012, 11:30 PM   #7
Missouri Bound's Avatar
I've cut down a lot of doors and merely ripped a piece of 2X to size and made a new strip at the bottom. A table saw is the only tool required.
Do you want it your way or the right way?
Old 01-01-2013, 01:16 AM   #8
ive done this hundreds of times but the glue joint created doesnt hold for long due to how the veneer cant absorb the new glue due to the original glue filling its pores..
as for the lockset, your better off building your own jamb and using a blank door so you can set the door knob at the correct height
The Following User Says Thank You to woodworkbykirk For This Useful Post:
mae-ling (01-01-2013)
Old 01-01-2013, 02:42 PM   #9
Rewards Points: 454
I usually take the filler piece that i cut off the door and peal the venear off and glue and nail i back in ,no need to rip another piece.
scottktmrider is offline   Reply With Quote
The Following User Says Thank You to scottktmrider For This Useful Post:
Old 01-01-2013, 03:43 PM   #10
That really doesn't make any sense, at least to me. Where you are putting the new filler is in an area that wasn't previously glued. Proper glue coverage and clamping and I can't see it going anywhere.
Old 01-01-2013, 06:13 PM   #11
how doesnt it make sense. the veneer of hollow core doors arent very thick when the door is made they load it with glue .. when you put in the filler strip the glue doesnt bond to the inside of the veneer as it would to fresh wood.. eventually the glue joint of the filler strip fails no matter how good a clamp job is done. there is a reason high end guys dont use hollow cores.. their junk and its just a call back waiting to happen.. same as installing bifold doors yer
Old 01-01-2013, 06:36 PM   #12
Thanks for all the answers so far. Sounds like cutting off the door on the bottom might not be the best idea.
I'm not quite sure I understand what you mean. Take a look at the picture I took (excuse my artistic "skills"). Right now the rough opening is actually 82" inches, but once drywall is hung on the ceiling, the drywall will be 1/2" below the rough opening. I didn't actually think about this when I framed it. But even if I had thought about it, I would have not been able to frame the ceiling any higher. I assumed that I'll have to at least add a 2x4 to the top of the rough opening, so that it is lower than the drywall. Or am I wrong? Can you maybe elaborate?
It'll be carpet. I just checked the framing, it is quite precise. The opening on both sides is exactly 82" right now (or 80 1/2" if I add a 2x4 to the top). I checked the floor where the door is going to open to, and it is pretty much flat, maybe 1/16" less clearance when the door is all opened.
I assume this is what mae-ling was referring to? I guess I don't quite understand what this means. Looking at the picture I took, do I have a header?
Only the door calls for a trim, but obviously I'll have to skip the one on the top, or at least it will be very minimal.
Rough opening for door only 80 1/2"-dsc_0536-medium-.jpg
Old 01-01-2013, 06:53 PM   #13
Do not add the 2x4 (red lines) to the top. Drywall through it then install door.
The Following User Says Thank You to mae-ling For This Useful Post:
kwikfishron (01-01-2013)
Old 01-01-2013, 07:02 PM   #14
Oh ok, so the top jamb would then go directly onto the drywall, so i only lose 1/2" instead of 1 1/2". I guess, getting a regular cheap 80" hollow core door is going to work after all. With minimal or no cutting.
Old 01-01-2013, 07:06 PM   #15
kwikfishron's Avatar
Rewards Points: 228
Originally Posted by TomU View Post
only the door calls for a trim, but obviously I'll have to skip the one on the top, or at least it will be very minimal.
Looks like it will work to me. Improvising in basements that weren't designed to be finished living space is pretty common.
kwikfishron is online now   Reply With Quote
Changing Window Size TinaV Remodeling 3 11-06-2012 01:30 PM
Making rough opening narrower?? ratherbefishing Carpentry 8 09-27-2011 04:57 PM
exterior door rough opening jgcable Building & Construction 2 05-24-2011 08:08 AM
Odd sized existing rough opening in interior door. t_mott85 Remodeling 2 11-24-2010 12:56 PM
New rough opening to basement - spiral staircase benjamincall Building & Construction 8 07-16-2010 06:53 PM
