Rough Opening For Bi-fold Doors - Building & Construction - DIY Chatroom Home Improvement Forum
Old 10-09-2008, 04:59 PM   #1
Rough opening for bi-fold doors
My husband and I are about in the process of opening up a closet and hanging bi-fold doors. We have already opened up the wall and decided on using (2) 24" bifold doors. Of course the doors we bought come with all the hardware and NO INSTRUCTIONS!
My questions is this...Does anyone know what is the necessary rough opening for this project?
I would really appreciate any suggestions.
DCCook
DCCook is offline   Reply With Quote
Old 10-09-2008, 05:14 PM   #2
the Musigician
DangerMouse's Avatar
if you know the brand of the doors, google that to see if you can find their website for install directions.
hardware=track and screws? i'd GUESS the track length should tell you the width. if the track fits, the doors should too?
DM
Old 10-09-2008, 05:21 PM   #3
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
Bi fold doors are gnereally labeled according to the actual "finished" space. Example: a 24" bifold, will fit into a 24" space, with about 1/4" or so to spare.
What you first may want to consider is actually your "Finished Opening", when it comes to laying out the space needed for a bifold door arrangement.
If you are planning on installing jambs around the area, then you need to account for the additional 3/4" + 3/4" of jamb thickness (3/4" on each side). So the rough opening (framed opening) would be equal the 24" + 24" (2 bi-fold doors) + 3/4" + 3/4" (Each side's Jamb) = 49-1/2" For the rough opening. If you are planning on doing a sheetrock wrapped opening with corner bead, you would allow for 1/2" + 1/2" of sheetrock. But then add for the corner bead that protrudes out from 1/8" to 1/4" more on each side. So either way, you may want to account for the additional 1-1/2" of needed space to figure your total R.O.
- Build Well -
Old 10-09-2008, 05:30 PM   #4
Example:
- Build Well -
Old 10-09-2008, 06:04 PM   #5
Custom Cabinet Maker
Basically all interior doors EXCEPT FOR SLIDERS will be plus 2" in both width and height for the RO. As in a 48" door will require a ro of 50 x 82
skymaster is offline   Reply With Quote
Old 10-09-2008, 07:19 PM   #6
Much thanks...
Thanks for your help. We had to take another trip to Lowes (as with any project we start) but we should be able to finish the door tomorrow and move on the laying the flooring.
Old 03-20-2009, 09:25 PM   #7
DCCook
try this link
http://daveosborne.com/dave/question...inishing18.php
bpacsuta is offline   Reply With Quote
It's hot outside. Keep the exterior doors and windows closed if running the A/C? Taylor Crockett HVAC 3 07-07-2008 05:04 PM
rough opening for glass block oxicottin Remodeling 5 05-04-2008 08:01 PM
Replacing hollow doors with 6 panel eehammar Remodeling 2 02-16-2008 01:27 PM
Hanging doors on drywalled and finished opening dk_99 Building & Construction 9 12-31-2007 09:34 AM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 04:57 PM
