Rough Framing A Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-12-2010, 11:50 PM   #1
Rough framing a window
Hello All, I am replacing 3 old jalacy windows with one smaller double hung window. I need to know how to rough frame the new window. Thanks in advance for any advice.
hwdruman is offline   Reply With Quote
Old 06-13-2010, 07:46 AM   #2
Not sure how much you are looking for. The new opening should be about 1" larger that the window frame dimensions, and be plumb/level.
Old 06-13-2010, 09:53 AM   #3
Exact framing can be slightly different
Header size depends upon window width
Old 06-13-2010, 05:35 PM   #4
Registered User
Rewards Points: 5,266
A picture and measurements of the old window and new window measurements (only) would be helpful......
Be safe, Gary
Old 06-14-2010, 10:03 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,142
Since you say the new double windows are smaller than the existing triple unit, your existing framing is fine. It is just a matter of closing up the opening to the RO size of the new unit. i.e.: nail 2 by 4's to both sides of the existing opening till it is the size you need. Do the same on the bottom (or top) if you need the height smaller.
Coastal South Carolina
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 01:41 PM
Framing and Trimming Basement Window mjkpainting Carpentry 2 06-28-2009 10:33 AM
Need Help Framing a Window johnpma Carpentry 10 06-11-2009 11:42 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Re-sizing a window opening shtoink Carpentry 5 09-04-2008 11:47 AM
