Rough Framing For An Exterior Door (not Prehung) Measurement Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-15-2011, 04:03 PM   #1
rough framing for an exterior door (not prehung) measurement question
It's a 32" door.
Rough measurement instructions say to add 2" to the width of the door and 2 1/2" to the height of the door.
The width is pretty straight forward, but the height is where i have a question.
I don't have the height measurement on my... but let's say it's a 6'8" door (80")
My rough openning would then be 80 + 2 1/2 = 82 1/2
Am I measuring my 82 1/2 inches starting from the subfloor or starting from the top of the bottom plate?
thanks!
graysqwrl is offline   Reply With Quote
Old 08-15-2011, 06:28 PM   #2
Rewards Points: 5,336
You're measuring the vertical from where the prehung door rests upon.
Ron
B. Franklin 1759
Old 08-15-2011, 06:38 PM   #3
so... you're saying measure from the subfloor, but add in an extra 3/4" for the hardwood I'll be putting down?
so... 83 1/4" from the subfloor, right?
Also, it's NOT prehung (not that I really believe that makes any difference)
Old 08-15-2011, 06:44 PM   #4
Framing Contractor
Why isn't an exterior door prehung? Are you making this yourself?
Joe Carola
Joe Carola is offline   Reply With Quote
Old 08-15-2011, 06:58 PM   #5
The house is 106 years old. I'm re-using one of the original doors that I had stripped down and stained.
Now please tell me if I'm measuring correctly so I can finish the rough in.
Thank you
Old 08-15-2011, 08:51 PM   #6
Thank you
You need to state:
The size of the door.
What sill type you are using and how thick it is.
Where is the frame coming from?
Ron
B. Franklin 1759
balloon framing window question mrs.doolittle Carpentry 5 02-04-2011 04:16 PM
Above grade framing and a few framing question jreed Building & Construction 6 01-16-2010 10:56 AM
Framing Question flati Building & Construction 10 01-12-2010 10:24 AM
I have a question on changing trusses, I am framing an attic room. wackerjr Building & Construction 17 01-22-2008 07:36 AM
Basement Framing Question lpcon Building & Construction 7 04-17-2007 10:18 PM
