Rough Framing Costs - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-24-2008, 06:38 AM   #1
Rough Framing Costs
Hi,
This is my first post in this forum.
I'm located in the New England region (Massachusetts). I'm (in the planning stages) building a new house (about 2600 sq ft..... 2 floors, 1400 sq ft 1st and 1200 2nd)...and will be looking for a GC to build a weather tight shell and I'll be finishing the rest. My question .... Is there a way I can estimate the cost of rough framing labor? I realize there are numerous variables that can determine the final cost (roof lines, pitch, etc.) but for now, I'm just looking for general way to estimate this cost so I don't design a house outside my budget. If there is a way to do it by sq ft (either wall area-floor area??)...I can get a building package quote from the local lumber yard I deal with for the materials... so it is the "labor" part I'm referring to. Thanks very much for your insights and help.
BTW... great forum.
RINAIL is offline   Reply With Quote
Old 03-24-2008, 04:23 PM   #2
Rewards Points: 5,336
I think you're under a misconception about the term GC and what it implies. The cost of a GC includes a fee based on the cost of the job. That includes all the trades that are involved and what they are doing. If the house costs $175,000 to enclose, the GC might charge a 20% fee for the job. Or 30%. The more complicated the job, the higher the fee.
At least, that's the way I do it.
Ron
Old 03-24-2008, 04:59 PM   #3
ron6519.... thanks for your reply.... I'm under no misconceptions (at least I don't think I am)... I understand cost plus, fee based...etc.. Most contractors, I've been talking with are cost plus 15 -18%..... I'm aware that "GC's", if they don't have their own crew, sub out the rough framing aspect of the job.
if anyone can suggestion how a rough framing crew determines the cost of the labor... is it by the square foot... and if so...is it square foot of the foot print by each individual floor's sq footage... or is it individual wall square footage.
Thanks again for any insights and help.
Old 03-24-2008, 05:41 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
They do it by studying the plans. There is no framer in his right mind that is going to quote a job simply based on SF, with no plans.
Here's the complete formula to obtaining a framing price quote:
(Qualified Framer or GC) + Plans = Price to frame.
- Build Well -
Old 03-24-2008, 06:11 PM   #5
"if anyone can suggestion how a rough framing crew determines the cost of the labor... is it by the square foot... and if so...is it square foot of the foot print by each individual floor's sq footage... or is it individual wall square footage'
Bottom line is that you need plans to determine actual cost. Theoretical cost of a theoretical structure is of no use to you. It could actually get you in financial trouble.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
Willie T (03-31-2011)
Old 03-24-2008, 09:04 PM   #6
BuilderRemodeler
Determining a Home Floor Plan and planning is needed Prior to your Framing Estimate.
Your Local Home Builders Association may have the average dollar amount per square foor for building homes in your area if that helps.
The Plan's Layout Determines the square footage dollar amount.
BuilderRemodeler
40 pages of useful Home Remodeling Charts, Home Addition Guidelines, Home Painting Tips, How to Determine a Deck Size and Build Your Deck Online! www.BrandsConstruction.com
www.HomePlansForFree.com One Story Ranch Detailed Free Home Plans
darylbrands is offline   Reply With Quote
Old 03-31-2011, 09:18 PM   #7
Originally Posted by RINAIL View Post
Hi,
BTW... great forum.
I am a framer in nw ohio. Our prices range from 3.50 to 8.00 a foot($1.50 for garage) depending on the house. So if you figured it 5.00 a foot, labor would be $13000(for a 2600 sqft home). that includes setting all windows and ext doors and tyvek. Vinyl siding runs about $65 a sq(average house around for that size of home would usually run between $1800 and $2200) the roofer runs about the same, $65 a sq,( average house that size 1600 to 2000) I am sure thinigs are different up there, but I thought i'd just let you know how we priced things. hope that helps a little.
nickkorak is offline   Reply With Quote
Old 03-31-2011, 09:30 PM   #8
Old School
Willie T's Avatar
Basic sq. ft. pricing is for real estate agents... and very hungry carpenters. You guys would have loved the old days when I was a super for U.S.Home. The rate for framers was 63 cents a sf. Yes, I said CENTS.
Willie T
Last edited by Willie T; 04-01-2011 at 04:54 PM. Reason: Added the word "OLD" to 'date' this time period
Old 03-31-2011, 11:37 PM   #9
Too Old
At 63 cets you must be talking piece work for framing the walls but not framing the whole house. A 1500 sq' house would be $945 which would be right for framing, plumb and line of the walls. I do $3.60 on a single story basic house not including materials.
havalife is offline   Reply With Quote
Old 03-31-2011, 11:58 PM   #10
Rewards Points: 1,016
I think Willie T was speaking to a rate from the past, not current time.
The Following User Says Thank You to vsheetz For This Useful Post:
Willie T (04-01-2011)
framing material estimate maydoug Building & Construction 38 06-12-2009 01:32 PM
shower rough in frusteration! Lmiller Plumbing 5 03-13-2008 12:24 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 09:27 PM
Wood Framing Getting Wet? stagger19 Carpentry 2 05-10-2006 08:37 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 04:23 PM
