Rough Fascia Needed? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-10-2009, 08:10 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,342
Rough Fascia needed?
I'm working on the roof for a small addition. This roof will tie into the existing roof with a 16" overhang on both. Both new and existing are hip roofs. The old roof has the fascia directly attached to the rafter tails. The fascia is in good shape so I won't be replacing this on the old roof.
My plan is to match the construction of the existing roof. Before I cut the rafter tails to length. Is there any reason why I should add a rough fascia to the new roof or is it OK to attach the fascia to the tails?
TIA
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 08-10-2009, 08:30 AM   #2
Registered User
Termite's Avatar
Around here most fascia also serves as the subfascia. Personally, I'd install a subfascia or blocking between the rafter tails. Not completely necessary though.
Old 08-10-2009, 12:23 PM   #3
Registered User
Rewards Points: 5,492
Your choice. "My plan is to match the construction of the existing roof." The only place I would use it is at the gable over-hangs, to hold up the barge rafter (fly rafter) if the fascia board was not sufficient enough. Then, side nailed from the second rafter back- into it, and through it-into the gable tail. Cutting the gable tail 1-1/2" shorter first. Or if you have closed soffits and need it as a nailer. Be safe, G
Plastic fascia and soffit panel attaching to it. 4just1don General DIY Discussions 1 07-22-2009 09:26 PM
New roof and Sheathing - Install new fascia before or after? hartkem Roofing/Siding 2 06-01-2009 12:12 PM
12" Fascia Board Maralind Roofing/Siding 6 01-26-2009 05:26 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
Are fascia boards rough carpentry? Paul58 Building & Construction 10 04-19-2006 10:18 PM
