Rotten Wood Around Window - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-27-2011, 10:09 AM   #1
Rotten wood around window
I have rotten wood around my windows. Can I replace the rotted wood without removing the windows? Any advice is greatly appreciated. Pictures attached - thanks!
Rotten wood around window-img_1637.jpg   Rotten wood around window-img_1639.jpg   Rotten wood around window-img_1640.jpg
acestar is offline   Reply With Quote
Old 04-27-2011, 10:25 AM   #2
usually you can if it isnt part of the window itself. most wood around windows is installed after the window is installed.
The Following User Says Thank You to DannyT For This Useful Post:
oh'mike (04-27-2011)
Old 04-27-2011, 10:29 AM   #3
DIY staff
Rewards Points: 7,174
You will find that a Harbor Freight multi tool is very handy to have with that type of repair---
Along with a table saw-----Mike----
Old 04-27-2011, 10:34 AM   #4
Too Short? Cut it Again!
Be sure to address issues as to why moisture is getting to the wood (and into the walls if this is the case) and causing it to rot. In your case, it looks like their are more than a few miles on that trim and it has happened over time?
There are also epoxy products that can come in handy for hard to replace or intricately shaped pieces of wood. I first starting using products from this company restoring old sailboats years ago. There are others though.
http://www.abatron.com/cms/
Obviously, good epoxy resins are expensive and probably not indicated where you can just switch out the trim.
Old 04-27-2011, 11:02 AM   #5
Thank you for the quick response! I'll give it a try and see what happens.
The Following User Says Thank You to acestar For This Useful Post:
oh'mike (04-28-2011)
Tags
replace window , rotten window frame , window
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 06:03 PM
Bathroom window issues? Mantaray14 Remodeling 11 12-04-2009 07:40 PM
window replacement--pvc or aluminum covering the old wood?? pls help !! silvershot77 Building & Construction 6 05-27-2009 03:31 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
