Rotten Threshold... Need Advice On Removal - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-25-2013, 11:33 AM   #1
Rewards Points: 578
Rotten threshold... Need advice on removal
As you can see, the board beneath the door threshold is rotten. Its not weak, not at all, but it is rotten and i assume it needs replaced. I know this will make me sound like a complete newbie, but ive never done this before and i want to make sure its right before i screw up.
How do i go about getting this board off of the joists? The house has 2x6 joists and this particular bit of board is sitting on top of the door piers. I know you cant see the piers in this picture but they are there now. Do i need to remove the piers first, then wiggle it free with a crowbar or is there another method?
Please help me before i end up breaking something!
Come and see the progress on my mobile home paradise!!! (NEW PICS ADDED ON 01/26/15!!)
http://www.diychatroom.com/f49/compl...emodel-168570/
TrailerParadise is offline   Reply With Quote
Old 01-25-2013, 12:22 PM   #2
Rewards Points: 578
Anybody?
Old 01-25-2013, 12:47 PM   #3
Rewards Points: 150
I would use a sawzall!
CJIII is offline   Reply With Quote
Old 01-25-2013, 09:52 PM   #4
I would just cut a piece and go right over it. Done...
paintdrying is offline   Reply With Quote
Old 01-25-2013, 10:35 PM   #5
funfool's Avatar
Rewards Points: 534
Just my thoughts on that photo, and let me add that I also live in a mobile home and have for my self rebuilt and while living in them sold 3 and in my 4th now, also owned 2 houses and sold them also.
First thing, that is not normal for the threshold to rot out like that, is a leak somewhere that is causing the damage.
I have seen your other post on this rebuild, and say nice job!
I would open up the walls on the interior around that door. Is a water leak going on that is running down the walls and showing on the threshold,
You should see a clue of where the water is coming from, and follow it back to the source and fix it.
Just looking at the photo, there is more rot then what you see. looks like some patches to left side of door, I wonder what those are about and if they are not the cause of the problem?
But you really need to open that wall and find the issue.
Now seems like a good time.
funfool is offline   Reply With Quote
Old 01-25-2013, 11:10 PM   #6
Rewards Points: 578
wall is open. rot came from water coming in around the porch light. its been fixed. damage has not
Mirror Removal - Demo Advice? trekkaround Remodeling 13 11-18-2012 11:34 PM
Replace threshold? thaKing Windows and Doors 4 07-17-2012 12:27 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 07:12 PM
Lead paint removal Luken8r Painting 3 05-15-2008 08:05 PM
Need advice...rotten floor joists on house I'm buying strngelitlgrrl General DIY Discussions 5 08-01-2005 10:14 PM
