Old 05-03-2011, 10:26 PM   #1
rotten subloor
the tongue&groove subloor is rotten under some of the outside sill walls, how do I replace the wood or fix existing wood
majakl is offline   Reply With Quote
Old 05-04-2011, 07:10 AM   #2
Licensed P.E./Home Insp
Aggie67's Avatar
rotten subloor
There is no one step by step single way to do this. The objective is always the same (support the wall so you can take the load off the element you want to replace), but the temporary structural elements are determined in the field, based on load paths and the surrounding "good" structure that you have available. It goes quick when you assess it properly and get your temporaries in place. But I've seen contractors struggle for an entire day or more fiddling with the assement part, when it really shouldn't. I did one a few weeks ago that involved the sill, joist ends, and subfloor in one quadrant of a house, and it took 2 framers about 3 hours to put proper supports in for that corner of the house, but you have to know what to do and have the right material, which requires that you have a very good understanding of the load paths in the structure you're working on.
Aggie67 is offline   Reply With Quote
Rotten bathroom subfloor tallycat77 Flooring 14 02-08-2013 10:59 AM
Replacing Rotten Band and Sill organick Building & Construction 14 04-13-2011 12:50 PM
Help - rotten exterior wall support studs Charbl General Discussion 2 11-15-2010 07:27 AM
Help! How do I fix rotten wood under door? glamgirrl Building & Construction 20 08-08-2010 11:22 PM
Rotten Wood janet.hampton Carpentry 1 07-04-2010 03:22 PM
