Rotten Outside Beams On Mobile Home - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-13-2013, 11:00 AM   #1
rotten outside beams on mobile home
if I start removing beams will the mobile move or become uneven I think I will have to use jack posts ?
derrick smicer is offline   Reply With Quote
Old 08-13-2013, 11:41 AM   #2
Rewards Points: 14,300
Only "beams" in a mobile home would be the steel beams running down the middle.
Got a picture, impossible to see your house from here.
Guessing you mean the outside rim joist.
If that's so then yes that's what's holding up your walls and floor.
mae-ling (08-14-2013)
Old 08-14-2013, 03:45 AM   #3
roofingquotes's Avatar
Well, I guess it'll work still. Whether you remove it. But you can try removing if. See if it woks or not.
roofingquotes is offline   Reply With Quote
venting from mobile home through new metal roof jeanmoon Roofing/Siding 8 05-01-2015 08:53 AM
Replacing end walls in mobile home. rrolleston Building & Construction 8 02-02-2013 03:19 PM
Coleman DGAA mobile home furnace issue baluna HVAC 9 04-07-2012 08:55 AM
Mobile Home Electrical Panel Replacement rrolleston Electrical 2 01-28-2012 05:27 PM
Dyrwall for Mobile Home Suncrest79 Building & Construction 3 03-04-2009 07:05 AM
