Rotted Wood Section Under Bathtub, What To Do? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-14-2013, 12:57 PM   #1
Question
Rotted wood section under bathtub, what to do?
Hello, recently i took my old bathtub out of my house, it was in very bad shape and had been leaking, finally took it out, it had a date of 8/1978, old.
Anyways when it was finally removed, we noticed a section about 6in X 6in of rotted wood on a section of the wood on which the bathtub sits on.
it doesn't appear to be a section which supports the bathtub, however still must be fixed clearly, what is the best way to do this?
Rotted wood section under bathtub, what to do?-2013-02-14-12.19.44.jpg   Rotted wood section under bathtub, what to do?-2013-02-14-12.19.48.jpg   Rotted wood section under bathtub, what to do?-2013-02-14-12.19.38.jpg   Rotted wood section under bathtub, what to do?-2013-02-14-12.06.14.jpg
spaita is offline   Reply With Quote
Old 02-14-2013, 05:39 PM   #2
Rewards Points: 13,732
Going to have to cut out the subfloor and replace it.
Really also need to get rid of any of that old steel or cast iron plumbing.
Old 02-14-2013, 06:23 PM   #3
DIY staff
Rewards Points: 7,174
Black pipe looks like ABS---should be fine to leave that as is---
To replace the bad wood---cut out the bad---add 2x4 blocking to support the new ply wood--then glue and screw it down---
The soft wood under the wall? Not much you can do about that---leaving it alone should not cause any future problems.
Old 02-16-2013, 04:07 PM   #4
Smile
thank you both for your help, this forum is great!
The Following User Says Thank You to spaita For This Useful Post:
oh'mike (02-16-2013)
Tags
bathtub , remodel , rotting , wood
Rotted wood under siding: Repair Help? (See Pictures) LevTownMike Remodeling 3 06-25-2012 05:03 PM
Wood basement wall below grade - what to do? Jer739 Building & Construction 1 10-04-2011 10:03 PM
How do replace rotted wood in window frame? Sherm Windows and Doors 7 07-13-2011 01:50 PM
easiest/proper way to repair rotted pine roof wood noquacks Roofing/Siding 5 05-16-2011 09:35 PM
Wood furniture care/ Cleaning (I ?!#?!? up) bli182nk General DIY Discussions 0 05-22-2010 01:31 AM
