-   -   Rotted wood section under bathtub, what to do? (http://www.diychatroom.com/f19/rotted-wood-section-under-bathtub-what-do-171930/)
spaita 02-14-2013 01:57 PM
4 Attachment(s)
Hello, recently i took my old bathtub out of my house, it was in very bad shape and had been leaking, finally took it out, it had a date of 8/1978, old.
Anyways when it was finally removed, we noticed a section about 6in X 6in of rotted wood on a section of the wood on which the bathtub sits on.
it doesn't appear to be a section which supports the bathtub, however still must be fixed clearly, what is the best way to do this?
:thumbsup:
joecaption 02-14-2013 06:39 PM
Going to have to cut out the subfloor and replace it.
Really also need to get rid of any of that old steel or cast iron plumbing.
oh'mike 02-14-2013 07:23 PM
Black pipe looks like ABS---should be fine to leave that as is---
To replace the bad wood---cut out the bad---add 2x4 blocking to support the new ply wood--then glue and screw it down---
The soft wood under the wall? Not much you can do about that---leaving it alone should not cause any future problems.
spaita 02-16-2013 05:07 PM
thank you both for your help, this forum is great!
