Old 08-07-2012, 09:09 AM   #1
rotted window sill - repair or replace
I have a picture window with single hung windows on either side and
I recently discovered a rotted window sill / sub sill / under one of the single hung windows extending under the picture window. part of the jamb is rotted out too. Is this something worth repairing or is it more advisable to replace and rough in new replacement windows?
caseymcdougall is offline   Reply With Quote
Old 08-07-2012, 09:56 AM   #2
I have gas!
Clutchcargo's Avatar
Could you post some pictures? Maybe it's not as bad as it sounds.
If it does come down to replace as opposed to repair, I'm of the camp that would say, full tearout and replace with new construction windows. I don't like replacement windows.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 08-07-2012, 01:16 PM   #3
the pix i have are too big for the site.
i'll take new ones tonight and post tomorrow.
thanks for your help.
Old 08-07-2012, 01:20 PM   #4
found a site online to resize it.
Old 08-07-2012, 01:24 PM   #5
sill & subsill
Old 08-07-2012, 01:33 PM   #6
Moderator
kwikfishron's Avatar
It depends…if you’re wanting update the windows with modern double panes then this looks like a good time to do it.
If you’re happy with what you have then a decent carpenter should be able to replace the sills in a short day if that’s all that’s rotted.
If you want to DIY then a Sawzall and a Table Saw are a must.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is online now   Reply With Quote
window sill repair from inside the house joshg3p0 Carpentry 3 06-10-2010 08:07 AM
how to replace a rotted sill in an older home kmc123 Building & Construction 10 11-18-2009 09:12 AM
Replace door sill = Need new door? NNJGUY Carpentry 23 09-01-2009 02:54 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 08:38 PM
repairing rotted sill dwlodyka Building & Construction 4 02-27-2008 08:38 AM
