Rotted Sole Plate Replacement - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-27-2010, 05:48 AM   #1
rotted sole plate replacement
i have an old single story wood frame garage that has recently been re-sided.the rotten sole plates on the endwalls are a single layer of 2x8 on cinderblock -it appears the floor slab was poured after the garage was framed and its height exceeds the plate height-.i was wondering after supporting the existing wall with a cripple wall ,can i cut up on the wall studs an inch and 1/2 or three inches if necessary to provide me with the space i need to remove the old plates and install the new one?
rgw28 is offline   Reply With Quote
Old 01-27-2010, 06:13 AM   #2
Remodeling Contractor
yes. Then use pressure treated plates sitting on new sill insulation. shim if needed to fully support the studs you cut.
Old 01-27-2010, 06:17 AM   #3
first-thank you-
what type of sill insulation?i was going to use some tar paper doubled up-is that ok?
Old 01-27-2010, 06:28 AM   #4
Sill insulation will air seal the concrete to plate connection as well as act as a capillary break to prevent water wicking into the wood. It comes in a roll. About 6" wide 1/4" thick and is pink foam material.
Old 01-27-2010, 06:32 AM   #5
great! sounds like a great idea-
thanks again
Rotted sole plate in bathroom firemanter Carpentry 3 05-30-2013 02:14 PM
Rotted sole plate in bathroom firemanter Building & Construction 3 11-11-2008 10:06 PM
Rotted sill plate replacement help handyd123 Building & Construction 2 08-25-2008 06:02 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
Adding closet to carpetted room. Sole plate on top of carpet? roysoto Building & Construction 2 09-22-2006 11:01 PM
