Rotted Sill Plate - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-19-2011, 08:34 PM   #1
Rotted sill plate
I started the process of residing my house and i came across about 10 feet of rotten sill plate on top of my block foundation but, only about the outside 3"s of the 2X10 is rotten. So i was thinking about chiseling out all the rot and sliding in a treated 2X4 to make it a full 2X10 just in two pieces. Was wondering if this would work any ideas would be great don't really wanna have to go threw the process of jacking up my house to fix this.
Thanks,
Nick
Neschenbrenner is offline   Reply With Quote
Old 06-19-2011, 09:01 PM   #2
DIY staff
Rewards Points: 7,174
A picture will help us a lot on this. Is the bottom bearing portion of the 2x10 joist also damaged?
Old 06-19-2011, 09:08 PM   #3
Most of is where the floor joists sit is ok maybe an 1" would need to be removed. I'll try and get a picture tomorrow if the rain holds off.
Thanks for the fast reply!
Old 06-20-2011, 06:09 AM   #4
DIY staff
The sill plate can be replaced in sections---you don't need to do all 10 feet as one piece.
Help! Rotted Sill Plate Corner 3 Story House petersjse Carpentry 19 11-04-2010 06:19 AM
Rotted Sill Plate and Joists jhawk4ever Building & Construction 2 08-30-2009 08:03 PM
rotted sill plate, joist ends and stud bottoms oh my. slowjo Building & Construction 16 05-02-2009 09:43 PM
Rotted sill plate replacement help handyd123 Building & Construction 2 08-25-2008 06:02 PM
replacing rotted sill plate and rim joist behind a deck ledger board tommyt Building & Construction 2 08-11-2008 07:38 PM
