Rookie Garage Residing Q About Sheathing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-10-2011, 04:21 PM   #1
rookie garage residing q about sheathing
hello-
i want to reside a 25 yr old garage. the bottom of the 1/2" celotex sheathing sucked up some h2o over the years, and looked like this when i took off the old siding.
i've decided to cut off the bottom 2' all the way around and put on some pressure treated 1/2" OSB in it's place. i've noticed there is some water damage throughout the celotex...you know, a splotch here or there.
my q's are:
  1. is my 'plan' the correct way the best overall way to do this job?
  2. do i have to replace all boards that have water stain on them, or can i leave the partially (but still intact) stained boards up and re-side over them once i replace the lower pieces to seal up the bottom?
thanks so much!
rookie garage residing q about sheathing-bottom1.jpg   rookie garage residing q about sheathing-bottom-2.jpg   rookie garage residing q about sheathing-watered1.jpg   rookie garage residing q about sheathing-watered2.jpg
berbes is offline   Reply With Quote
Old 05-10-2011, 04:50 PM   #2
Framing Contractor
Rewards Points: 118
First off, if you haven't already done it, is to take care of the water problem. That old brown board really sucks up water and gets deformed when it is wet. With osb currently at $6 a sheet, I would probably remove all the brown board and do the bottom with treated ply like you said, and the rest with 7/16 osb.
sixeightten is offline   Reply With Quote
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-25-2011 11:58 PM
Support for garage foof sheathing. Jim F Building & Construction 3 10-23-2010 01:46 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Full piece of sheathing at garage door pomelo Building & Construction 1 04-03-2009 08:20 PM
