Rooftop Tiled Terrace Leaking - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-14-2011, 06:21 PM   #1
rooftop tiled terrace leaking
We have a tiled terrace over part of the house and it is leaking to the garage and a room below (mudroom). The area is about 250 square feet. Some of the tiles are cracked and some have deteriorated grout and may have contributed to the leak and maybe fixing the tile and re-grouting would be a fix, but I plan to put new tiles and wanted to know what the proper way to waterproof such an area. I haven't removed any tiles to see what is underneath and don't know the extent of the damage below the tiles. I have heard that you can lay some thick plastic sheets or use hot mop method, but it was not from an expert. When I try to tackle this project myself, I want to be sure I am using the most appropriate waterproofing method to prevent future leaks. Thank you in advance for any advice.
Roman34 is offline   Reply With Quote
Purchased home, upper tiled terrace deck is leaking we think..how to fix properly tracydr Flooring 0 01-11-2011 03:59 PM
Leaking Box Window Omeleto Building & Construction 9 02-19-2010 04:40 PM
leaking roof couchguy Roofing/Siding 1 02-13-2010 04:43 PM
Tiled seat in Shower leaking? pinkcenturygirl Plumbing 3 11-17-2008 04:49 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
