Roofing Felt For T1-11 - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-14-2008, 09:22 PM   #1
Rewards Points: 260
Roofing felt for T1-11
Location Florida:
I noticed some people put roofing felt or house wrap in between the siding and wall studs. Is this counterproductive? I'm thinking it could trap moisture in between the walls. Should anything be used?
bluefitness is offline   Reply With Quote
Old 11-14-2008, 10:16 PM   #2
General Contractor
I'm not clear on your current condition. Will this be t-111 over plywood? The tyvek is a breathable material. It keeps drafts out and allows the wall to breath so moisture does not build up. I've been to some seminars and Tyvek seams to be the best product out there.
Illinois G.C. is offline   Reply With Quote
Old 11-14-2008, 11:54 PM   #3
Registered User
Termite's Avatar
Felt has been used for decades, and remains one of the very best ways to combat moisture intrusion into a wall. Nothing wrong with it at all.
I agree with IllinoisGC that Tyvek is probably a better option, given the technology.
Either way, if moisture gets behind your T1-11, it'll rot. You definately need one or the other to protect the wall itself.
Old 11-15-2008, 04:24 PM   #4
Rewards Points: 260
No, it is T1-11 directly nailed to the wall studs. There was no weather barrier in place when the house was built. I'm debating on whether to put something in between the studs and siding.
Old 11-15-2008, 04:43 PM   #5
BUILDER / REMODELING CONT
buletbob's Avatar
Yes I would Use 30lb felt paper or the TYvek. BOB
Choosing The "Right" Roofing Contractor, How To Evaluate Who Is Right! Ed the Roofer Roofing/Siding 27 04-25-2013 06:10 AM
Roll Roofing Repair IfItAintBrokeFixItAnyway Roofing/Siding 9 09-13-2009 06:32 PM
How do I attach the 15# roofing felt to the subfloor? rncopper Flooring 8 06-23-2008 10:17 PM
Roofing felt mattflytx Roofing/Siding 2 09-10-2007 12:01 AM
roofing felt farrington135 Roofing/Siding 15 04-29-2007 09:33 PM
