Roof Ventilaton - Hip Roof (ridge Vent, Fan, Power Vent ?) - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-02-2011, 05:38 AM   #1
Rewards Points: 83
Roof ventilaton - hip roof (ridge vent, fan, power vent ?)
The house has a gable roof over the garage (gable vent on driveway end) tied into the hip roof over the main part of the house.
The roofer installed a ridge vent across both the gable and hip sections of the roof . He left the power vent (near the peak of middle of the hip roofed section ) the but told me to disable it which I did. However, the attic seems to be hotter than before. What are my options here ( run the power vent, add some more passive vents ("turtle back") on the hip roof fairly near the ridge etc ?
- Thanks
rkpatt is offline   Reply With Quote
Old 06-02-2011, 06:16 AM   #2
For ridge vents to work properly, there must be an equal volume of air supplied by soffit vents. It has been a while since I did roofing, but since hip roofs come to a point, I would install a Whirly Bird vent at the peak. This lets the hot air out at the top. You would still need soffit vents.
Old 06-02-2011, 04:21 PM   #3
Rewards Points: 83
I have soffit vents but believe that the amount of ridge vent area for them exhaust through is less . I have used the tubines on other houses in the many years ago past and have found them to stop rotating after fairly short period of so that's why I though about just installing the passive vents ("turtlebacks ").
Ridge Vent and Power Vent? etern33 Roofing/Siding 7 06-06-2011 07:06 AM
Are exposed nails on a roof ridge vent acceptable? Bmcox Roofing/Siding 2 12-04-2010 05:59 PM
ridge vent vs. gable ceiling fan snarkk Roofing/Siding 1 09-22-2010 03:06 PM
Need Help with Ridge Vent on Unusual Roof MSBOY Roofing/Siding 1 03-24-2010 09:46 PM
Ridge Vent - Low-pitched roof? brianp Roofing/Siding 2 05-08-2006 08:32 PM
