Roof Vent And Vent Stack Gasket Installation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-17-2011, 01:33 PM   #1
Rewards Points: 1,062
Question
roof vent and vent stack gasket installation
when installing a roof vent and a DWV vent stack gasket on a roof, was wondering if the bases of either should go on top which layer: sheathing or tar paper ? pretty sure they should go below the shingle but unsure about the two layers underneath...
thanks in advance
Old 02-17-2011, 03:35 PM   #2
Imagine the flashing as the next shingle. Put it on top of the row below. Then cut the adjacent row of shingles to fit around the pipe. Then the row above that may need to be trimmed a little. Tar each layer
mrgins is offline   Reply With Quote
The Following User Says Thank You to mrgins For This Useful Post:
amakarevic (02-17-2011)
Old 02-17-2011, 10:51 PM   #3
Question
yes but i don't understand ON TOP OF WHICH LAYER i should place the vent and the gasket: bare OSB sheathing or tar paper which goes on top of the sheathing ??
thanks
Old 02-18-2011, 12:09 AM   #4
Rewards Points: 338
thanks
since it is considered part of the shingle layer, it goes on top of the tar paper.
here is a good walk-through with pictures:
http://www.hammerzone.com/archives/r...t_flashing.htm
NitroNate is offline   Reply With Quote
The Following User Says Thank You to NitroNate For This Useful Post:
amakarevic (02-18-2011)
Tags
roofing
no vent stack thru roof? walt1122 Plumbing 5 02-16-2011 10:56 AM
Main vent stack moving / resizing / removing (///AG) SFX Group Plumbing 11 11-16-2010 06:47 AM
new roof, ridge vent was in est, but not installed... Zel1 Roofing/Siding 29 09-01-2010 04:30 PM
low-slope roof and leaky ridge vent downers Roofing/Siding 15 02-21-2008 11:35 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
