Roof Truss Tie Plate - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-18-2013, 02:38 PM   #1
Rewards Points: 396
Roof truss tie plate
Is it ok to use tie plates or mending plates for a roof stuff instead of plywood gussets for a shed roof?
detroittigerfan is offline   Reply With Quote
Old 09-18-2013, 03:10 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
what are you trying to accomplish?
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 09-18-2013, 04:06 PM   #3
Rewards Points: 396
what do you mean what am I trying to accomplish? The joints in TRUSSES where bottom chord meets top. I want to know if its ok to use mending plates or tie plates instead of those plywood gussets?
Old 09-18-2013, 04:10 PM   #4
GBrackins's Avatar
I do not see where you said TRUSSES in the OP, that's why I asked what are you trying to accomplish. A shed roof is typically a single pitched roof (1/2 gable). Make sense why I ask?
Got any photos that you could post?
Gary
Old 09-18-2013, 04:20 PM   #5
Rewards Points: 396
Photos have nothing to do with what I asked.
Old 09-18-2013, 04:22 PM   #6
GBrackins's Avatar
ok, guess I'm not intelligent enough to help you then
good luck! sorry you are having a bad day
Gary
Old 09-18-2013, 04:25 PM   #7
Rewards Points: 396
sorry ya having a bad day. Let me ask you this question instead:
can't you just nail 2x4 lookouts directly to the end gable rafter if your doing like a small overhang? But if you do it that way how would you connect at the very peak? Also, for the 2 end gable trusses instead of doing a web design for bracing in between the top and bottom chords can you install end studs instead?
Old 09-18-2013, 04:28 PM   #8
GBrackins's Avatar
are you talking about an extended rake on the gable end? if so we do them all the time by making a ladder frame from 2x4's and securing it to the gable endwall studs with a couple of structural wood screws.
Gary
Old 09-18-2013, 04:29 PM   #9
GBrackins's Avatar
when I say extended rake I'm talking about something like this
http://www.houzz.com/extended-roof-rake
Gary
Old 09-18-2013, 04:55 PM   #10
Rewards Points: 396
Dont they need to be secured to the 2nd rafter?
Old 09-18-2013, 05:58 PM   #11
GBrackins's Avatar
there are two ways of doing an extended rake, one as shown on page 43 of this link
http://awc.org/pdf/WCD1-300.pdf
the other way (one I described) is seen in figure B on page 111
http://www.fpl.fs.fed.us/documnts/us...73chapter4.pdf
in my area most are ladder framed (2x4's or 2x6 so they look like a ladder) and attached directly to the gable end wall studs.
either way works
Gary
Old 09-18-2013, 06:05 PM   #12
Rewards Points: 396
either way works
So the way you do it your attaching the ladders to the end gable rafters and not to the second rafter in?
Old 09-18-2013, 06:07 PM   #13
Rewards Points: 396
Oh i forgot to ask. In between the truss bottom and top chord are the diaganol webbing. Instead of going diagonal and the 2 end trusses can I just do straight up and down end gable studs?
Old 09-18-2013, 06:07 PM   #14
GBrackins's Avatar
our gable rafter sits inside a notched stud (gable end wall) and then the plywood sheathing is attached to the face of the wall.
then the ladder frame is attached. roof sheathing then extends out to rake edge of the ladder frame.
Gary
Old 09-18-2013, 06:09 PM   #15
GBrackins's Avatar
yes a gable end wall truss have vertical members usually at 16" o.c. for attachment of wall sheathing.
if you go with outriggers (2x members that go back to the 2nd truss) then the gable endwall truss is shorter than the inboard truss
Gary
Rebuilding a garage roof - rafter vs truss KyleInBrooklyn Building & Construction 30 08-29-2012 07:51 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 04:17 PM
Roof truss installation Mike47ma Building & Construction 3 08-21-2011 03:01 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 06:37 PM
