Roof Truss - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-18-2013, 12:56 PM   #1
Rewards Points: 396
roof truss
I am building roof trusses for a shed and using metal truss plates to connect at joints. My question is for the rake overhang I know I frame lookouts but how can I connect the lookout at the peak if there is a metal bracket at the very end rafter?
detroittigerfan is offline   Reply With Quote
Old 09-18-2013, 01:11 PM   #2
Rewards Points: 454
If you don't have it sheated yet notch a 2x4 flat into the gable and and butt it into the side of the 2nd truss.Basically you will dato the top cord on the gable.Than attach the gutter board to that and put your soffit under that.I hope i haven't confused you let me know and i might be able to explane it better.
scottktmrider is offline   Reply With Quote
Old 09-18-2013, 01:17 PM   #3
Rewards Points: 396
I understand that part but can't you just nail 2x4 lookouts directly to the end gable rafter if your doing like a small overhang? But if you do it that way how would you connect at the very peak? Also, for the 2 end gable trusses instead of doing a web design for bracing in between the top and bottom chords can you install end studs instead?
Old 09-18-2013, 03:36 PM   #4
Rewards Points: 454
You can do it that way its just a little stronger if you can tie it back to the trussess.
If i understand about tieing in at the ridge.You will make plumb cuts on the soffit boards being the fly
rafter and the board on the wall and than put 2 studs together at the very top.And i dont really understand about what you mean abot the 2x4's on the truss
Old 09-18-2013, 03:46 PM   #5
Framing Contractor
Rewards Points: 120
Nail it through the gusset.
sixeightten is offline   Reply With Quote
Rebuilding a garage roof - rafter vs truss ksm1000 Building & Construction 30 08-29-2012 06:51 PM
Interior dimension on a 28' roof truss? ebliever Building & Construction 4 07-06-2012 03:16 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Roof truss installation Mike47ma Building & Construction 3 08-21-2011 02:01 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 05:37 PM
