Roof Truss - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-31-2012, 01:32 PM   #1
roof truss
House built in 1971 has howe trusses spaced at two foot on centre, pitch is 4 12 the trusses are 2x4 top and bottom anybody know what the span would be that the truss would carry
jrcc is offline   Reply With Quote
Old 03-31-2012, 01:45 PM   #2
Civil Engineer
Rewards Points: 4,566
The maximum span the truss is rated for is a function of the load, and the strength of the lumber used to make the truss. The load is a function of your location and the code you operate under. The rating of the lumber can be supplied by the truss manufacturer, whose name is probably stamped on the trusses. I suggest you contact them, they probably know exactly what span their truss was designed for, based on your location.
The Following 2 Users Say Thank You to Daniel Holzman For This Useful Post:
jrcc (03-31-2012), PaliBob (03-31-2012)
Old 03-31-2012, 02:15 PM   #3
truss
hi, ive done a lot of framing what are you concerned about ? load-or rot, what size of bottom cord does the truss have 2x4 or 2x6 ? that will tell you alot are you wanting store stuff up there or ?
shockme123 is offline   Reply With Quote
Old 03-31-2012, 06:12 PM   #4
Im not worried about rot im concerned about load the bottom is 2x4 I want to remove a centre wall below them and am wondering if it can be done. What confuses me is my garage which is attached to my house uses the same truss has no beam down the centre where in the house there is
Old 03-31-2012, 06:41 PM   #5
Haverhill Trade 1965
You might get 2 of these. I posted an answer and it vanished so here it is, (again maybe). Normally trusses are designed to span from outside ends of the bottom cord, or sometimes there is a vertical bearing block from bottom to top cord. If the center wall has one plate at the top, or has studs 16" on center with one top plate then it shouldn't be a bearing wall. If the truss has a simple W bracing it should be a clear spanning design. The manufacturer will probably ask questions like this.
Duckweather is offline   Reply With Quote
Roof truss installation Mike47ma Building & Construction 3 08-21-2011 03:01 PM
Broken Roof Truss chris0914 Building & Construction 6 11-25-2010 12:59 AM
roof truss explaination jusolson Building & Construction 2 12-03-2009 10:45 AM
Laying new roof after removal of old roof rupal Roofing/Siding 9 11-30-2009 05:00 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 06:37 PM
