Roof Sheathing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-07-2013, 06:25 PM   #1
Roof sheathing
Hi guys,
I am building a small little house for my son and have some questions. When I go to sheet the roof should the edges from one side of the gable roof meet the other side of the gable roof at the peek? Its just a small play house so no ridge vent. Also, I have no end gable overhang so no soffit. How would I go about install fascia without an overhang?
markharmon is offline   Reply With Quote
Old 05-07-2013, 07:41 PM   #2
Roofmaster
Rewards Points: 2,210
Originally Posted by markharmon View Post
Hi guys,
That would be sheathe, Mark, like in Sheathing. Yes they should meet at the ridge.
Old 05-07-2013, 07:57 PM   #3
roof sheathing
Mark ,
As far as your gable facia is concerned , you can attach it directly to your gable . If you are putting siding on the gable , install the siding first , then the facia on top . You can put a spacer between the facia and the gable to give it more depth .
Az.
Az Framer is offline   Reply With Quote
Old 05-07-2013, 08:58 PM   #4
Originally Posted by Az Framer View Post
Mark ,
Az.
the fascia boards i see have that 3/4" lip though so how would that work with no overhang sub fascia board?
Old 05-08-2013, 04:57 PM   #5
Mark ,
not sure that I'm following you about the 3/4 " lip .
The facia that I use is most often a 1x or a 2x with 4 square edges .
Az.
Old 05-08-2013, 05:51 PM   #6
Framing Contractor
Rewards Points: 126
The plywood does not need to touch. You can slide a 2x6 up flush to the top of the roof sheathing and face nail it into the gable end. Your drip edge will cover this.
sixeightten is offline   Reply With Quote
Old 05-08-2013, 08:50 PM   #7
Are you talking about the plywood meeting the sub fascia board?
Old 05-08-2013, 08:51 PM   #8
Mark ,
Az.
Im talking about the aluminum fascia boards. They have a lip at the bottom.
Old 05-10-2013, 09:40 AM   #9
facia
Mark ,
What I think you are talking about is an alluminum skin that covers the wood . If so , install the wood to the gable . Then cover the wood with the skin .
Az.
Roof Sheathing mrus Roofing/Siding 8 04-07-2012 06:59 PM
is my sheathing rotting? *pics* Nospammer Roofing/Siding 24 03-07-2012 09:06 PM
Roof Sheathing Thickness Clutchcargo Building & Construction 8 09-23-2009 01:13 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 05:37 PM
