-   -   Roof sheathing (http://www.diychatroom.com/f19/roof-sheathing-179024/)
markharmon 05-07-2013 06:25 PM
Roof sheathing
Hi guys,
I am building a small little house for my son and have some questions. When I go to sheet the roof should the edges from one side of the gable roof meet the other side of the gable roof at the peek? Its just a small play house so no ridge vent. Also, I have no end gable overhang so no soffit. How would I go about install fascia without an overhang?
jagans 05-07-2013 07:41 PM
Originally Posted by markharmon (Post 1174556)
Hi guys,
That would be sheathe, Mark, like in Sheathing. Yes they should meet at the ridge.
Az Framer 05-07-2013 07:57 PM
roof sheathing
Mark ,
As far as your gable facia is concerned , you can attach it directly to your gable . If you are putting siding on the gable , install the siding first , then the facia on top . You can put a spacer between the facia and the gable to give it more depth .
Az.
markharmon 05-07-2013 08:58 PM
Originally Posted by Az Framer (Post 1174602)
Mark ,
Az.
the fascia boards i see have that 3/4" lip though so how would that work with no overhang sub fascia board?
Az Framer 05-08-2013 04:57 PM
Mark ,
not sure that I'm following you about the 3/4 " lip .
The facia that I use is most often a 1x or a 2x with 4 square edges .
Az.
sixeightten 05-08-2013 05:51 PM
The plywood does not need to touch. You can slide a 2x6 up flush to the top of the roof sheathing and face nail it into the gable end. Your drip edge will cover this.
markharmon 05-08-2013 08:50 PM
Are you talking about the plywood meeting the sub fascia board?
markharmon 05-08-2013 08:51 PM
Originally Posted by Az Framer (Post 1175226)
Mark ,
Az.
Im talking about the aluminum fascia boards. They have a lip at the bottom.
Az Framer 05-10-2013 09:40 AM
facia
Mark ,
What I think you are talking about is an alluminum skin that covers the wood . If so , install the wood to the gable . Then cover the wood with the skin .
Az.
