Roof Sheathing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-01-2013, 10:34 PM   #1
Roof sheathing
Does anyone here know if it is code compliant to use 7/16" OSB for roof sheating in NYS?
NASCARFANGO88 is offline   Reply With Quote
Old 04-01-2013, 11:06 PM   #2
Roofmaster
Rewards Points: 2,172
Do your local authorities having jurisdiction go by the IBC?
Personally, I would not even think about it. Just because you can does not mean that you should.
The Following User Says Thank You to jagans For This Useful Post:
NASCARFANGO88 (04-03-2013)
Old 04-01-2013, 11:19 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
if you'd like a nice ripple effect to your roof ..... then 7/16" would be perfect. I never specify anything less than 5/8"
here are the building codes for NY state http://publicecodes.cyberregs.com/st...010-999999.htm
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
The Following 2 Users Say Thank You to GBrackins For This Useful Post:
NASCARFANGO88 (04-03-2013), woodworkbykirk (04-02-2013)
Old 04-01-2013, 11:27 PM   #4
I believe they do go by the IBC.
Old 04-01-2013, 11:32 PM   #5
Well, its just a small addition and I have a lot of 7/16" OSB and a lot of scrap 2x4's. What I was going to do was put a 2x4 every 16" between the trusses I know its a lot of extra work but it would stop the rippling effect I think. Also, 5/8" plywood here is $26 a sheet and I need 12. Is this a bad idea?
Old 04-01-2013, 11:33 PM   #6
GBrackins's Avatar
oh, and I forgot ...... Welcome to the Forum! Go #24
Gary
The Following User Says Thank You to GBrackins For This Useful Post:
Old 04-02-2013, 06:12 AM   #7
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
we use no less than 5/8 we'll even go as far as using 3/4" t &g plywood, but 7 /16 no thanks too flimsy
woodworkbykirk is offline   Reply With Quote
The Following User Says Thank You to woodworkbykirk For This Useful Post:
Old 04-02-2013, 08:14 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,744
+1 to the other posters.
Even if it were permitted...don't do it. Go thick and do it once. Your roof and structure will thank you.
The Following 2 Users Say Thank You to Windows on Wash For This Useful Post:
Old 04-03-2013, 02:02 AM   #9
I would like to thank everyone for their input, and I will take back the 7/16" osb back and get 5/8" plywood even though its double the price now, it will be worth it for the long haul.
The Following 2 Users Say Thank You to NASCARFANGO88 For This Useful Post:
fetzer85 (04-03-2013), GBrackins (04-03-2013)
Roof Sheathing mrus Roofing/Siding 8 04-07-2012 07:59 PM
is my sheathing rotting? *pics* Nospammer Roofing/Siding 24 03-07-2012 10:06 PM
Roof Sheathing Thickness Clutchcargo Building & Construction 8 09-23-2009 02:13 PM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 08:33 PM
Rubber Roof and Roof Deck vianak Roofing/Siding 2 10-09-2008 06:37 PM
