Roof Sag - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-13-2008, 12:27 PM   #1
Roof sag
I have a shed roof that covers an enclosed porch. The pitch on the roof is minimal. The problem is the center of the roof is starting to sag. One of the problems this causes is water running behind my gutters and I'm afraid under the shingles. Other than tearing down the entire roof and starting over, do you have any suggestions for raising the center of the roof. The ceiling is covered so I have not had an opportunity to remove the ceiling to determine what was used for the rafters.
Eric F is offline   Reply With Quote
Old 04-13-2008, 01:16 PM   #2
Rewards Points: 5,336
"The ceiling is covered so I have not had an opportunity to remove the ceiling to determine what was used for the rafters.'
Well, that's the place you would start. Sounds like the roof is under structured. What is the unsupported span and what are the joists that are spanning it. Where do you live?
Answer those questions for a start.
Ron
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 10:44 AM
leaking tar and gravel roof meleis Roofing/Siding 9 01-05-2008 11:27 PM
Ventilating Roof with no ridge? NateHanson Roofing/Siding 7 12-30-2007 05:33 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 08:28 AM
