:confused1:
I am building a workshop that measures 16 ft across the front and 20 ft deep. The rafters will be front to back (on the 20 ft dimension). I will have a vaulted ceiling , exposed rafters, with no interior walls or posts. I had planned to use wood I-beams, as I did with my floor joists, for the rafters, but I am not sure about the ridge board/beam. I am getting advise from local builders/framers with conflicting information.
Some say I can use my 9 1/2" I-beams for rafters, and a single 2"x12" ridge board across the 16' span at the ridge. Others are saying I need an LVL ridge beam. I have read that a ridge board/beam when used with wood I-joists for rafters should have a ridge board/beam that can support the entire roof load, since the I-beams are not designed to tolerate the compression that can occur in my situation.
Can someone give me a definitive answer to this question:
Can I use a single (or double) 2"x12" board for a ridge board/beam when I use wood I-beams as rafters. They will have a 10-12 pitch across a 20 ft total span (10 ft from front of wall to ridge). ..OR.. could I use a 2"x12" ridge board/beam across the 16' width if I use 2"x8" or 2"x10" dimensional lumber rafters? Both cases will have no interior supporting walls or posts and no ceiling joists. Just supported on the outside walls.
Thanks.
Thanks.
