Roof Peak Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-07-2013, 02:13 PM   #1
Roof peak question
Hello everyone. I have a brick home, and the peak on the house is 8" wide tongue and groove planks. Built in 1949, i am pretty sure it is original and needs to be replaced. Is there a tongue and groove alternative? (Cement board, vinyl, etc. Haven't found anything like that at the local stores. I don't really want to use a T-111 type product. Any advice would be appreciated. Also, is vinyl ok to use for facia board? Thanks!!
dlcook66 is offline   Reply With Quote
Old 05-07-2013, 05:12 PM   #2
GBrackins's Avatar
Rewards Points: 2,108
not going to find it I'm afraid in the big box stores. Check with a local lumber yard or local mill. There are places that can duplicate what ever you need, and I'm sure if the lumber yard don't have it that can point you in the right direction. I've had 1850 dragons reproduced for a Victorian home.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 05-07-2013, 07:59 PM   #3
Roofmaster
Rewards Points: 2,210
Holy Crap, Thats a lot of Dragons, Gary!
The Following 2 Users Say Thank You to jagans For This Useful Post:
MTN REMODEL LLC (05-07-2013), RWolff (05-07-2013)
Old 05-07-2013, 08:03 PM   #4
Roofmaster
Do you mean that the roof deck is 8 inch T&G? Is this vaulted construction? Can you post some pictures? If its just the deck you should be able to go right over it with plywood or OSB.
Old 05-07-2013, 08:19 PM   #5
Old School
Willie T's Avatar
I think he is talking about the gable ends, above the brick line at the bottom of the roof.
Willie T
Old 05-07-2013, 08:22 PM   #6
GBrackins's Avatar
opppppssss ...... 1850's dragon thanks for the catch jagans!
that's how I took it also Willie
Gary
Old 05-07-2013, 09:54 PM   #7
Roofmaster
It was a joke, guys.
Old 05-07-2013, 09:59 PM   #8
Roofmaster
Oh the gable ends! Thanks Willie. Silly me. I'm thinking Pike Peak, or Antifreeze. I guess Im easy to fool.
I could not see the picture. Were you able to?
Old 05-08-2013, 09:37 AM   #9
Roofmaster
I Think your best bet is to install a one foot wide Kynar coated Batten seam roof panel on your gable ends it will look good, and last for 50 years with no maintenence. Install ASTM D226 Type 2 felt on the end wall. Install PT horizontal furring 2 ft. OC. and install the metal panels. You can stick some insulation in between the furring too. You will need a Z metal broken up for you, and some other flashing, but you get the idea.
Tags
exterior , peak , siding , tongue and groove
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 12:47 PM
Another roof ventilation question Jim F Roofing/Siding 9 05-13-2010 07:51 PM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 12:35 AM
steel roof question kindrngentlr13 Roofing/Siding 5 06-18-2008 11:29 AM
Hip Roof Ventilation Question tecboy Roofing/Siding 7 06-17-2008 09:37 AM
