Roof Overhang Knee Brace Design - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-18-2009, 08:45 PM   #1
roof overhang knee brace design
can anyone help me find an attractive way of building a knee brace (AKA "bracket") to hold up a 2X6 barge rafter? the rafter is 10' long and is attached to the ridge at the top.
i made one brace out of oak, let-in 45 degree joints, and timberlocked. it took forever, but looks pretty decent.
i'd like to get the sort of craftsman style. would you make it out of 2X4? 4X4?
the roof is already totally covered, so i can't really go back and do "lookouts" or anything.
thanks.
wombosi is offline   Reply With Quote
Old 05-18-2009, 09:14 PM   #2
Registered User
Rewards Points: 526
http://books.google.com/books?id=E5S...e+lookouts&lr= My
Craftsman look-outs are 6" in from the house corners, not on the corner trim.
Measure the over-hang on roof, build the bracket 3" longer.
Do not notch anywhere on bracket, as per picture, not necessary. Make your seat cut in the barge rafter 3-1/2" wide. Slip the premade bracket up, nail or Timberlock screw into place. Be safe, G
Old 05-18-2009, 09:17 PM   #3
thanks man.
so you'd make the brackets out of 4X4 material?
is it OK to use green oak? i've got a bunch of scrap left over from a job.
just pre prime it all?
thanks.
Old 05-20-2009, 02:37 PM   #4
Registered User
Rewards Points: 526
I would not use green anything, as it will shrink and open the joints. Mine are made from 4x4, then painted. 45* the nose all around, leaving a 1"x1" blunt point. Be safe, G
Old 06-06-2011, 10:00 AM   #5
What should the spacing between brackets be?
gmoening is offline   Reply With Quote
Old 06-06-2011, 09:25 PM   #6
Registered User
Rewards Points: 526
Depends on the roof load and barge rafter size; http://www.flickr.com/photos/5546567...-95238041@N00/
http://www.flickr.com/groups/craftsman/
Gary
The moving Ice Dams after using a roof rake ?? Canufixit Roofing/Siding 9 02-05-2009 07:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
