Roof Over New Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-12-2008, 11:00 PM   #1
Rewards Points: 154
Roof over new deck
I'm in the process of building a new deck and the other day I saw a roof style that I liked. It was made of corregated translucent fiberglass supported by redwood 2x6 rafters, 24" o.c. Over my deck, this covering would be attached to the house and extend out about 8'. What size beam and post spacing would I need to support the outer part? I haven't been able to find any span tables that apply to this. Could a 4x6 doug fir beam with posts spaced 10' apart hold it up. I would like to minimize the lumber blocking the view. If I can't reasonably set the posts 10' apart in a couple sections, I'll have to add extra posts all the way to the ground, around 18'.
ovahimba is offline   Reply With Quote
Old 02-13-2008, 08:48 AM   #2
Remodeling Contractor
oldfrt's Avatar
Rewards Points: 186
A good start to help answer your question is to give your location,so loads(snow/wind) can be determined.
oldfrt is offline   Reply With Quote
Old 02-13-2008, 09:20 AM   #3
Rewards Points: 154
I'm located in the San Francisco Bay Area. At my location we don't get any snow or extreme weather. One or two days a year the wind might get up to 50mph. I'm guessing holding it down might be more of an issue than holding it up. My house is sitting on hillside.
Old 02-13-2008, 09:36 AM   #4
oldfrt's Avatar
Rewards Points: 186
I'm not familiar with the codes or practices there,but a good point to start is be by observing local trends in materials,like you've already done.
Like you say,holding it down may be your biggest concern ,so go with a good quality material.
Onduline used to have some decent panels.Maybe you can get omne ideas here.
http://www.onduline.com/anglais/onduline.php
Anyways,
I'm sure someone in your area will be along to set you on the right path here.
Old 02-13-2008, 12:32 PM   #5
You could skim this article too...
http://www.naturalhandyman.com/iip/i...oofpanels.html
perpetual98 is offline   Reply With Quote
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
Roof used as a deck - what is a good approach rogersor Roofing/Siding 3 09-19-2007 01:05 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Venting a shed roof with 2/12 slope atulc Roofing/Siding 5 08-25-2006 07:28 AM
add roof to patio deck elfyperz Introductions 1 05-17-2006 05:37 PM
