Old 04-06-2012, 12:42 PM   #1
JOATMON
ddawg16's Avatar
Roof Outlookers Questions....
There is just not a whole lot of info on the web when it comes to outlookers....
I am going to be doing a 24" eve on the side of the roof....
What is the typical spacing of outlookers? 16"? 24"?
How many rafters do you typically bridge them across? My rafters are going to be 16" OC....so I was thinking of notching 2 rafters (ridge rafter and the 1st inside one) and then butt nail the end of the outlooker to the next rafter (not notched).
Does that sound about right?
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 04-06-2012, 01:58 PM   #2
Hi there.
Notching two rafters and butting to the third would be the "double barrel" approach. Probably notching one rafter is plenty.
24" OC lookouts supporting your barge rafter should be plenty, too.
Have you framed your end walls yet? It not, you could lay those out so the top plates can accept 2X on edge, and not have to notch the hell out of your end rafter.
Good luck.
wombosi is offline   Reply With Quote
rubber roof over tar & thoughts on quote wfmrules3 Roofing 13 10-16-2011 10:00 PM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Getting a new roof - questions - please help Leah Frances Roofing 10 06-09-2009 06:04 PM
Metal Roof Repair Questions bruce3404@hotmail.com Roofing 3 09-17-2008 11:00 PM
questions about wood shake roof oraph Roofing 4 10-26-2006 06:10 AM
