Roof For New Garage - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-30-2013, 04:59 PM   #1
roof for new garage
I am building a new garage it is 33widex38 long I am getting the block layed up. the roof can i just install rafters and not ceiling joist also it will have a metal roof with perlins,, maybe use coral ties just asking may want to put lift in later. Thanks Raybob
rabob is offline   Reply With Quote
Old 12-30-2013, 05:19 PM   #2
Registered User
Rewards Points: 5,236
33', are they trusses? Cj's will not span 33', unless I'm missing something here...TJI's? What is on the plans? Collar ties are for wind, not structural. Moving the cj up off the plate requires a SE for the bolt/fasteners required.
Gary
Old 12-30-2013, 09:58 PM   #3
GBrackins's Avatar
Rewards Points: 2,108
Welcome to the Forum!
to eliminate ceiling joists one of two things must occur:
1. a structural ridge beam must be installed capable of supporting 1/2 of the roof load
2. rafter ties (ceiling joists are a specific type of rafter tie) must be installed within the lower 1/3 of the rafter length at a minimum of 48" on centers. of course you have to take a reduction in the strength of your rafters when using rafter ties.
see this link for typical rafter spans http://publicecodes.cyberregs.com/ic...9_8_sec002.htm
the reduction for rafter ties is shown below the table
hope this helps.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Hip roof garage ianmacneil Building & Construction 7 07-02-2014 12:18 PM
Cut into portion of garage pitched roof to make a deck. netsockets Roofing/Siding 1 04-19-2013 02:12 AM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Roof leak nightmare..... it won't stop amandat37 Roofing/Siding 52 04-22-2011 01:47 PM
